I hav noticed on my dash EPS. Just wanted to know wat this is?
Electronic power steering :)
Its just a check light like the ecu one.
and the VGR is the variable gear ratio
Alright guys, had the car up on jacks tightened up the front left shock, seems better, but while on the jacks noticed another problem which ill get fixed.
When I spin (not steer) the wheel back and fourth just a couple millimeters, i get a clicking sound, which isnt there on the other front wheel. I'm guessing this is the wheel bearing issue, so I'll get that checked out by a proper mechanic later. I'm glad I've at least spotted this now, having read some of the stories people have regarding failed wheel bearings.
Access to the steering rack boots is a bit harder so I probably wont attempt to do it myself just yet.
does anyone of you knows a good alarm system?
I want to upgrade my alarm and choosing between Brant and quiktrak. anybody have been using those? any feedback would be great. Thanks
W()()T i can make it to 4th of july cruise ! ! !
yeah boiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii ! !
hhahaha
are you gonna have the headers in by then
im snapping i wont have headers,sway bars or camber kit on by then, not even my shifter linkages!
if you have a whining sound while u're driving, then that will be the wheel bearing for sure, if you spin the wheel, and there is a clicking sound just when u started spinning it. It can be your driveshaft, there are gears or bearings in the outer driveshaft. u might need a driveshaft rebuild prolly.
but yeah, get it checked as well.
