Dang it Limbo
Can't help ya sorry man :(
I need to the 52mm one also, all my other gauges are that size already
Yup just replaced with new OEM boots :thumbsup:
You should make a bit more than me, you've got the 96-2000 kit yeah?
They have a slightly bigger turbo
Plus I don't have a boost controller yet and I end up with only 9 PSI in the high rev range.
What boost controller are you using?
Oh kool, how hard was it to get the OEM boots? reason im asking is because im taking it to the track on the 12th and if somthing is going to go bust before then i wont to make sure i can fix it :P
Ive got a custom conversion, using a gt28R
Using a profec B.
Yeah i thought id make more then that, ill go back for a retune eventually.
the gt28R is a great turbo for a built d. however u need the built block to really bring out its potiential on a d. i just posted up nhan's setup in the foced induction setups thread. his car on its first tune on 10psi made 141.3kw's atw. remember that is on 10 psi and his block was built. only thing is when he got it first tuned it didnt have a 3 bar map sensor installed. lots more potiential in the car. to bad he sold it, who ever owns the car now it very lucky
hmmm only 20-30kw difference roughly between a B & D
