yup like i said... :thumbsup:
worth giving it a try... or check even...
SO whats happenin next weekend for the cruise? same as last details?
Hey guys. Was out for a drive with some friends on a unlit stretch of road and kind of noticed two things about the (supposedly) OEM HIDs.
1) They don't shine very far, and the width of the road (and height) that they cover is severely limiting, i.e. They light up directly in front of me but if I look out the drivers side window, theres nothing, close to complete darkness. This is on full beam which I might add, doesn't do a whole lot beyond the low beams. It's particularly an issue if I'm going down hill to a dip and the road continues uphill after that; I just cant see anything on the uphill section.
2) The other issue is the actual brightness of the bulbs. It feels as though I had to almost squint to see even the areas that the lights did reach.
Ok so clearly I need to get them adjusted, which I will do, but my issue is that I believe even after adjustment, the light will be spread out even more and thus, even more dim.
I dont know much about HID's except that the higher colour temps reduce brightness, I should be running a 5000k bulb since once warmed up the light is white without any colour casts.
So is it possible to get higher output bulbs? Is that what H1, H4 mean? Should I look at getting the facelift projectors for my car? Has anyone compared their pre-FL HIDs with a FL HID's?
As a side note, my friends M3's Xenons were significantly brighter, covered a much wider stretch of road and when he put his full beams on, everything lights up. (Secondary halogen bulbs for full beam).
^ can't say much about the non-FL reflectors...but the projectors combined with the HIDs on the FL are really good...especially for long distance on a highway...
question is - why are you looking out the driver's window when you should be looking ahead while you're driving :confused: i'm yet to see a headlight that is able to bend light around :p
I'm on the same boat as Sai ann. My hid on my FL is very good.
hahaha...maybe he meant that the beam isn't spread wide enough till you can see it on the front side as well.Quote:
Originally Posted by sai_ANN
What I meant was when I'm cornering on a right hander, everything behind the A-Pillar, ie out of my drivers side window, is in near darkness.
Stock headlight housing no smoking out or anything. Just the regular mirrored inside.
Attached photo of my headlight below. Stock, yes? I bought the car from a dealer, I'm the first owner in Australia. They did the compliance and reinstalled the HID's.
