Originally Posted by
ekdez
i got some "short work" ones from one of the traders in black.
these are pretty good i reckon.. you get 4 wheel nuts and 1 lock nut as you want..
but reason i like these is because,
standard honda wrench shape wont screw or undo the 4 wheel nuts, i had to dig into my torque wrench kit to get a correct fitting one.. probably because, the holes which the nuts fit into on the wheel, are too small for both the nut and wrench to fit so i needed a smaller diameter piece to screw it in.
dunno if that makes sense.. hope it helps tho.
