RCAs could potentially correct the RC location issue, but it wouldn't correct the bumpsteer problem, you actually need a coilover with the steering arm mounted lower on the damper body. Even with the RCA you need to actually know how much it moves the arm and location of the RC, if you lower more than the RCA helps then you still have a problem, although not as bad as it would be without the RCA.
