You can only lose energy if something else gains energy. The only way the charge can lose heat energy is if it's temperature is greater than the surrounding cylinder walls/piston/head - otherwise the charge will gain temperature from the cooling system and give more energy back on the power stroke than you lost through compressing it!
A quick fiddle with excel:
Code:Pressure 8 psi
=0.055 N/mm^2
Area 81 mm
=5153.0 mm^2
Stroke 89 mm
Force 284.30 N
Work 25.30 J per cylinder per 2 revolutions
Cyl 4
Rate 3000 rpm
Power 2530.29 Watts
If we were compressing a reasonable quantity of air then I'd agree. It would heat up substantially and you'd lose lots of energy to the cooling system. Compressing cold vacuum is a different story...Quote:
So, even with an unrealistically high efficiency the work done creating at best a partial vacuum is not going to be the same as compressing in cylinder gas to pressures much greater than atmospheric...
