Thanks Lukey. Damn it- just looked at top hose after i read that- its leaking ~>:) More fun..
Aurnob88- **I CANT VIEW THE VIDEO** Yes you need 'valve lash' refer to
http://www.ehow.com/about_5102025_valve-lash.htm.
Essentially its a little play in the valve-train to allow for the valves/cams/gears to expand as they get hot- otherwise the metal would expand and the valves would not close (the heat expands the metals which forces the valves open a few 10ths of a mm. And/Or when the motor was cold the valve wouldn't open fully (because there is too much play).
Not hard to do (as we have a screw and lock-nut design)- try working with shims on motorbikes for something painful.
Hardest things to teach people is the way a feeler gauge should feel when its 'rubbing' between the faces instead of being pinched; and how to tighten the locknut without moving the screw. (DOUBLE CHECK YOUR GAP AFTER YOU"VE TIGHTENED THE NUT.)
Only really 'weirdo' tool needed is a 10mm socket (FROM MEMORY) with a inbuilt screw driver (if you want to get hi-tech and make your life even easier) and feeler guages (most people dont own a set). Both are around 12-15 dollars if you look around.
Team integra has an article on how to do it.
http://www.team-integra.net/forum/bl...djustment.html
Tex.
