Yeh bout that. Nope the whole thing isn't genuine. Depends which 1 u get. They range from 20 - 60 4 the h badge.
im so confused cause this other person has 3 thread in his one and the people were saying to unlock the bottom one and twist the whole coilover down?
this is mine with 2 threads?
http://pic70.picturetrail.com:80/VOL.../372971595.jpg
3 threads here
http://pic70.picturetrail.com/VOL187.../373004944.jpg
Thanks
OK, I always count the two rings holding the spring 1 and 2. The third one at the bottom is for the base, not the spring. Up spec coil overs are not just spring height adjustable but also shock body adjustable to a greater range of adjustment. Without going too deep into it, its to do with setting height of the car without disturbing the spring tension/rate.
With yours, (being flex) its just the fronts which has this. What I'm saying is, your car have been lowered (heaps). And the springs should be tensioned relative to the height of the car. If it has been done, I would dwell on it too much, so long as its at your desired height.
As for the rear, like most medium level coilovers, are only height adjustable via spring. There fore there is only two rings. One to adjust the height and one to secure it (locking ring). Normally the bottom one acts a locking ring.
But since yours is down all at way, you can only go up. Twist the top one up and then follow it with the bottom one. To get 1 finger gap on the rear, adjust it so there is about 10-15mm of thread under the bottom ring.
See pic below. When adjusted, both lower and raises the height of shock....therefore car!
But Pic 1, adjusts the car via the spring height, therefore changing the spring tension and rebound ability etc.....Pic 2 adjusts the height of the car without changing spring characteristics.
alright mad so simply just twist the 1st thread on my back to unlock it and then adjust it by rotating the second thread to raise it up and down?
ur da man george ! !
ok ran into a bit of trouble. man im a newb.
http://pic70.picturetrail.com/VOL187.../373013831.jpg
so i got 2 c spanners one on 1. and another one on 2. so i tried twisting the bottom one(2.) anti clockwise and the top(1.) clockwise to try to unlock it but its like not even budging with wd40.
After a few attempts now when i try to turn it both 1. and 2. are moving at the same time. is this meant to happen or is it still locked?
