man that silver s2k looks tough!
20's look ridiculous at any height, no offence.
Don't know how it would look but it would definitely rub even with "only" a 1" drop.
I'd probably run 235/45 on front and 255/40 on rear or 225/45 and 245/40 for less chance of rub.
All corners will need a roll and bumper tab relocation on the rear I reckon.
Just makes it look tougher or as those yanks say "hella flush".
It will probably make your handling worse cause you gotta run excessive negative camber though imo.
Short answer: no benefit apart from aesthetic
im running 18x9.5 +38 on the rears! but with stretched 235/40's and about -3.0camber (on stock body)
i rekn u could do that with 17s with 255/40s on and about -3.5* depending on how dropped ur gona be!
my fronts are 17x9 +44 (with a 15mm spacer,so effectively +29 which is basically the same as 17x 9.5 +35)
with the 9+44 the front fenders were getting mangled without the roll.
got the fenders rolled and -1.7* it worked fine.
but with the spacer on, needed to get at least -3.0* to get any clearance with the fender and this was with 225/45's on.
so will be more of a mission to run 255's on 9.5 +38!
8.5" can also run 255's :P Mainly for looks I guess since the 9.5+35 will be easier to fit since the 255's stretch on the 9.5 on a 9+22 its harder to fit, that's if they're going for the concave look.
For hard parking purposes basically lol
I think for CE28 I will be going 17x9 front +54 and 17x9 + 40 rear.
Should buy VEL's (DC5TYPER) ce28's his got 17x9+54 all round with heaps of tread left on his KU36.. however not too sure if it's sold :P
as vyets said +35 is the way to go
im planning to go +35 as well :D
maybe we can get them shipped together mad ;)
not ce28's but yea they are +35
http://farm4.static.flickr.com/3147/...2b021e69e2.jpg
http://farm4.static.flickr.com/3232/...ffbf400a7f.jpg
You wont be saying that when your tires keep throwing dirt on rocks on your paintwork. My fronts do that. But the rears dont.
Plus best advantage of NON-Stag is you can evenly rotate wheels front and back. Running different offset changes that. You might as well run 17x10 in the rear.
