Originally Posted by
TbM
yeh man theres a bit to do but after you done a few stereos its gets alot easier, id offer to give you a hand but your a bit far away iirc. you dont need to completely remove the dash, you only need to remove the centre console bit, if you follow my led conversion DIY up to the headunit removing part and ignoreing the cluster removing parts it will show you how to remove the parts you need to.
the remote cable connects from the back of the headunits harness to a small gauge wire that runs to the remote terminal on your amp, i usualy run this wire next to my power cable.
if you have trouble finding a grommet i can take a pic of where i ran mine.
