Why would even bother going ls vtec if your basically swaping a type R internals in there?
I thought the whole point was have a 1.8L True Vtec motor at the faction of the cost of type R motor?
Iunno... Reading old honda tech threads about building reliable lsvtec engines. Something about the stock ls bottom ends not being able to cope with the high revs and what not the vtec engines normally do/ the head and shit does, which can cause unreliable builds in the not so long run.
Was curious, as I was looking into a b18 lsvtec swap. But, costs a lot less to get vtec (doesn't have to be type r, but eh) pistons and crank than a whole engine. Besides, everybody is swapping out the stock parts (probably bar crank) for forgies these days to run power.
But yeah, from memory of the thread, you can have stock ls bottom end and vtec head, but it isn't likely to love life due to the extra stress of running in the higher rev range that the ecu and head would want.
Obviously, some info gets mixed up in my memory. find what's wrong/ what's actually not wrong, correct whatever. Bit of correction in the shitty memory bank helps bump things up
Man, are you Dylan Baxter by any chance?
