where is it on a d15b4?
But you will need the intake on to set the idle properly.The best way is to use a mirror to see into it so you know what you are turning in thier cause there a few different setups inside them but it the same principle,you just turn/tighter or looser to adjust the idle.
hi,
does dc2r had IACV? where does it located? (any photo could shows?)
thanks alot :)
Found the problem was FITV - removed and tighted 2 and a half turns all is sweeeet!!! Idles perfect now
Excellent.
DC2R doesnt have a FITV right?
The FITV DIY is Up!
You Have Cleaned the IACV BUT Your Idle Is Still High/Erratic? Adjust The FITV
what if you spray carby cleaner on the other holes ?
Do U mean the IACV when ya got it apart?
It will be fine,spray it everywhere but know CC dosen't work as well as Subaru Upper engine cleaner.
Just let it dry up before installing and get as much of the gunk out of there,you can use a flathead screwdriver to help get it off or metal brush etc
