Most cars have an FITV and this will need to be adjusted to fix your high/erratic idle.So you firstly need to find out if your engine has an FITV.If it does,here's what to do.
Aim:
To get the bloody car to idle/run properly!
Required:
* Screwdrivers
* A small mirror
Steps:
NOTE: The FITV/Throttle body needs to be fitted onto the engine do this,there is no need to remove the FITV or Throttle body.It needs to be on there so you can make the adjustment while the engine is running,therefore you know where is good.If it is removed you wont know!
That makes this SIMPLE
This is being performed on a d16y4 and it is Sooooo Easy!
Firstly,locate the FITV.It will be on the Throttle body.On mine it's part of the IACV on the bottom of the throttle body:
Remove the cover to expose the inside:
Use a small mirror to see in there:
Start the car and simply move that little part pictured above.Simply move it left or right with a screwdriver until the idle is fine or there abouts:
Note: All FITV's will vary in design but the principle is exactly the same.Get a mirror,look in there,you may just need to stick a flathead screwdriver in there and turn it like a screw,TOO EASY
Fine adjustments can then be made via the idle/air adjust screw:
Get it as close as possible but don't worry too much,once you have reset the ECU,this will be fixed!
Reset The ECU and Your Done!
Now,if you have a timing light,just check to see the timing hasn't moved,it shouldn't have but,well,you know cars...worth checking.
Adjusting Ignition Timing
Other comments:
A blockage in the IACV coolant hoses can sometimes cause this too Link
Now,you just need to Calibrate the Voltage on the Tps Sensor and your car will be SCREAMIN'!
Thanks to ME! for being strong willed/patient and sticking through ALL my car troubles in an effort to understand my throttle body issues and being successful!![]()
