jeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeezuz
If every one stopped trying to be so right, you guys might be able to give out some good knowledge, its obvious yous know shitloads about it
now
a question
Lookin at 19x8.5 for a DC5
the offsets the rim comes in is +35.
will use Coilovers for a big height drop, at least 3 inches...and a rear camber kit to square it up.
How wil this offset go?
I want maximum guard fill, and only want a max of 1.5-2 deg camber in the rear to help clearnace..thats a
maximum
The wheels are koya inox magic..
ps looksy here
http://www.1010tires.com/WheelOffsetCalculator.asp
AUSDM specs of 16x7 @ +45 offset leads to this
19x8.5 @+35
-Inner clearance 9mm less
-Outer position extends an extra 29mm
Is this gonna work or will the offset need to be lower?
Ill be using coilovers too, so i should have more room on the inside as the shock clearance should be better.
