YO! So i did a compression test. Cylinder 2 and 3 arent holding pressure so im assumign the rings are worn??
What do you guys think i should do now
What the compression readings?
Yeah it means the compression rings aren't any good anymore. But that doesn't mean the car will blow smoke. The compression rings and oil rings are separate so you can lose compression but not blow smoke, or you can blow smoke but not lose compression.
Still, I would assume your oil rings and compression rings are both gone, but really that should be blue-ish smoke not white.
Did you get a pressure test on your coolant system?
Err i forgot the exact readings but anyway, the smoke is actually bluish. To my untrained eye it seemed like just white. But taking photos of it and having a closer look at it, it really was a pale blue. And i didnt do it on my coolant. Im pretty sure my rings are ****ed
rreadings were 180 - 120 - 120 - 180
Interesting. The plot thickens...
Looks like im just going to replace my engine now anyway.. hah
Get the leak down test. Find where it's losing compression. If its just the HG I'd recommend fixing it. Not all that expensive.
Time for a D/B/H/F/Kswap for that (_)_) ass
you need a proper leakdown test... low compression could be headgasket, which i'm inclined to think it is
^ Would the headgasket make oil leak through?
