well nothing wrong with the bar; just a stick.. its the way its mounted to the car which is the issue
how much do itr sway bars go for these days? without the endlinks
Yeah the Bar an dthe endlinks are fine. Its the mounting brackets and th bolts supplied that are of very bad quality. One of you brackets snapped only got held together with the bolt which i originally used better bolts instead of the whiteline ones. Lucky i was installing the ASR at the same time to notice the piece. i have discarded the brackets since the ASR has the brackets for it.
wel guys i just checked mine then and it has cracked :eek: sooo shit. I had it mounted properly and with the tie bar. Damn, time to call whiteline and give em heaps. :thumbdwn:
Does anyone know somewhere in Victoria that will fix it?
Ouch! Another one...
is it only the 22mm bar that is cracking the subframe?
WTF are you serious ?
Get all the photos you can of the bar / mounting , and all receipts etc of the kit. Everyone who has had this happen deserves to be compensated in some way or form - it isnt coincidence.
Read this thread , and you will realise its not relevant to the swaybar size. Its the "HEAVY DUTY MOUNTING KITS" that whiteline has for the EK / EG and DC series. They are weak and questionable mounting.Quote:
Refer to my post - http://www.ozhonda.com/forum/showpos...8&postcount=50
Yeah just got off the phone with the guy at Whiteline, i gotta email in photos of the damage and receits and then they will asses it from there apparently.
when you do that.. you can email my picture too..haha
