Really? I past there quite often, since my tuner live up there. But I only saw your car once LOL
Hey guys took my cai off my car and there is a massive electrical fault with my car. The left headlight n blinker doesn't work. The central locking doesn't work and the air con doesn't work. I've cecked the fuses and they are all fine. Just want to know if any1 can help
are you getting those problems after you placed oem airbox in?
You've checked that all the plugs and cables are connected back where they are, too?
These problems only started 2 happen after the oem air box went back on. I've checked all the grounding cables. It's weird that only the left side of the car is doin it. Which is the side the cai was on
hey guys um question cause im a big noob. ok so gruppe m intake for our car does it need the scoop at the top or will it still suck air w/o the scoop that is bolted to your scuttle ??
photos steve photos! so without it the intake works fine ?
Was this any1's car on here? the plates look familar on the black sportivo
http://www.ozhonda.com/forum/showthread.php?t=128820
