Originally Posted by
Touge Tom
			ivé had a b20vtec for 3 years now built from the bottom up. you name it, type-r crank and low friction journal berring's , 84.5mm forged 13 comp pistons with 3 leaf head gasket to drop the comp to 12.5, forged rod's, block guard+welded in and the block planed and the cylinder's honed out, p72 vtec head, stage 3 + buddyclub cam's, skunk2 intake manifold, buddyclub 4-2-1 header, high flow cat with 2.5 straight through piping, toda racing fly wheel, exedy sports tuff clutch, type-r gearbox 4.7 final drive, koni adjustable shock's with lowered king spring's, blox 68mm throttle body, buddy club double coil valve spring's with titanium retainer's, jdm p30 ecu with apexi vafc2 and 240cc injectors. and this is my daily to and from work ,shop's, road trip's and home. iv'e had no problem's with this set up. it was buit @ good performance centre yennora by charlie and his crew. so why doe's everybody hate on the frankenstien?
