i havent dyno or even tuned the car yet..
havent gotten to that point yet
lol
lol
without the tune, any idle issues?
also my other question is, my current stock tb has the iacv block off plate and coolant bypass.. does it really matter if i get the b16a/b18c2 or ITR tb? i just noticed itr variants cost a bit more and have the iacv built in which i won't use anyway?
70mm here on a b16a
i have no issues with the idle at all.. the 62mm isnt overly huge so it seems ok with the skunk im. i got the itr tb.
b18c2 the earlier models have that built in iacv ur talking about.. i know there's been issues with idles and shit like that.. rpm raise n dropping. my mate had exact same issues.
he wasrunning a b18c2 with a older model b18c2 tb with that built in iavc.. now changed it to the same tb that it was meant to be running no issues.
if that makes ssense?
i know a friend is using a 68mm on his itr and has dramas with idle and cold starts.. pain in the ass..
:thumbsup:
yours/fatboyz setup is what got me intrigued... basically same setup except for CR and IM+TB.... i'm trying to account for the missing 5-7wkw across the rpm band and the 16wkw difference in peak :p
also if yous is 70mm.. what is the ID of the intake mani your using? ITR 64/62mm?
Dupac, what you mean by iacv built onto the b18c2 tb, Do you mean the Fitv?
You guys reckon it should be fine using a 68mm Tb with out porting my IM? IM currently at 64mm.
lol yeah fitv?
i dunno theres something on the older tb's on the b18c2.. that affects the idle
I understand how this all works now after a total of 5hrs continuous research on the physics and why bensons/fatboyz 70mm Tb works with the 64mm ITR IM....
you don't match TB size to IM inlet size.. you match TB size to the plenum volume..... but in their case its working like a taper anyway.. minus maybe some turbulance cause by a flat 'lip' on the IM due to it being smaller than the TB
Quote:
Originally Posted by MichaelDelaney @TeamIntegra
we running skunk2 manifold...not sure if the opening is ported...
im going to be using a ITR manifold with a obx 68mm TB... because i got nthe tb cheap... we will see how i goo that might be a month or two away
:thumbsup::thumbsup: let us know how it goes....
you gonna dyno after and overlay to your current?
i just ordered a 65mm coz it came with a free block off plate for whatever it is at the bottom of the tb (fitv/iacv..)
Would've loved to get this hyped one though... 68mm tapered to 65mm at the plenum.. worked out to be ~AU$210shipped
http://i5.ebayimg.com/04/i/000/ef/b9/560f_1_sbl.JPG
also found a 72mm tapered to 65mm with a free brand new oem tps already bolted and calibrated for ~AU$230 shipped
Those are the tb that we use... i find them much better than the billet ones...
