Originally Posted by
EUR003act
hey buddy :)
sorry been busy / sick :(
well i swapped back to the stock TB until i can bring it in to you to have the idle relearn done... prob wont be until next week... when i can get time :(
ok so update is:
the K20 head puts the water outlet in a different spot, so my custom made air intake now sits directly ontop of the radiator hose, meaning my intake is about 50-60degrees :( sucking in hot air = sluggish performance!
so i must make up a new intake... more time and money!
as for the stock ecu - when running with the J32A3 throttle body, the a/f ratios sit similar to what they used to, except under vtec... they used to sit around 11, they now lean out to 13.5... so im loosing power there!
im playing around with my options, i only drove it around for a day, so given more time i can see it learning... otherwise i may go piggyback ecu :zip:
