I believe solid is always better.
Personally I have an adjustable Whiteline rear sway bar 24mm that I'm very happy with ^_^
i also am running a 22mm rear swaybar on my EG and have to say its one of the best handling mods imho
also i have no intention of adding a thicker front bar as i like that when pushed the car will over steer as i find it more manageable
1:makes the car handle a lot flatter, it's night and day if you put one on with soft springs
2: sway bars reduce the grip at that end of the car, so if you put a rear and not a front the rear end will lose grip first. Putting a rear and not a front is a good way of reducing turn-in understeer
what would happen if i was to put a front and back one ? the eibach kit front one is like 23mm and the back is 25
dose the dc5 have the same rear subframe weakness as dc/eg
im getting koni yellows and springs made for it in like 2 weeks or so.
this neutral feeling, would it be like the way its driving now with a bit of understeer but will require higher speeds to understeer?
hmm not sure to go with the eibach front and back sway bar or just a whiteline back sway bar .
always thought two is best till now wow..
not sure if i have to get bushings changed along with the shocks and springs guys
1. It feels quite good, it definitely reduces understeer during spirited driving though I'll never feel its full effect because I have no intention of ever tracking my car =P
2. I think that putting a thicker/solid front sway bar would pretty much cancel the effects of the rear sway thus make making the rear sway redundant, so no front sway (only front sway I'm using is EP3R to clear Toda header)
