why eagle rods? don't like stock?
is this what knife edge crank looks like?
http://i47.tinypic.com/21o0bio.jpg
what's benefit?
tried searching for CNC closed deck, not sure what it does.
any extra bracing?
what's benefit?
any extra bracing?
The purpise of knife edging is it reduces the parasitic drag from the oil mist in the crank case. So basically it cuts through the mist and less oil condenses on the counterweights. All these kind of things cost horsepower. If you look at REALLY expensive race cranks, they'll be fully polished.
The last oem rod I used is sitting on my desk in 2 pieces snapped in the middle. And the exchange rate was excellent when I got all the parts for this motor so the eagle rods were a no brainer.
Yes that is what a knife edged crank looks like. But that looks like a manufactured one instead of a modified stock crank. In addition to the above, it pulls weight out of the crank and balances it. My only real criteria when putting the motor together was that it behaved like my old type r motor, so i wanted to take it above 8krpm all day at the track and not have to worry about it. The response with all the lightened internals is real nice so far.
B series motors have floating bores/open deck from the factory, and with b20s the sleeves are particularly thin compared to b16s and b18s. Closing the deck holds the top of the bores in place. There are plenty of theories as to weather closed or open deck is the way to go (open deck for best coolant flow vs closed deck for bore strength), I basically just told my engine builder that it would be used for racing and left it up to him - but I didnt want to sleeve the block. You can buy 'block guards' to fill the gap but they are rubbish and place uneven pressure on the bores often leading to ovalled bores and premature failure. The block was placed on a cnc machine to trace the block and bores, and a plate was machined up with tapered sides to suit the motor and is pressed into place. The bore is then honed after the plate is installed. Cooling is addressed with appropriate coolant channels in the plate. I do run a large radiator though.
Its most likely overkill on an n/a setup but after my last motor blew I wanted to make this one as strong as (realistically) possible.
Im sure others with more experience can offer their opinion on closed deck vs open deck and maybe vs sleeves. Generally pre fabbed block guards like golden eagle etc are frowned upon though.
Specs to compare to tinks are
bearing clearances 0.002"
piston to wall 0.0025"
ring gaps top - 0.014"
ring gaps middle - 0.02"
bore - 84.5mm
stroke - 89mm
piston volume - 43.4cc
deck height - Standard
head gasket - 0.03"
thanks very much for your insight
Appreciated.
To be honest im not sure of the exact specifics of assembly. It does run the stock girdle if that is what you mean?
Well there you go. Like i said im not sure. Motor was specced and assembled by Jhh with a few parts off my old type r b18c motor. I can find out though.
