7.8 + 48 is fine but offset is slightly weak for the back
8.5 + 50 might have clearance issue. best to try it on.
Spotted my old EP3 today in botany. Has purple rims. I want another one lol
door window seals.. anybody got the hookup?
stock wheels are 7" wide +45, so being 7.5 or 8.5 means the extra width needs to go either inside, outside or a combination of both. this depends on the offset.
8.5 + 50 means 24mm less inside clearance and extended 14mm on the outside. not sure if it will clear the suspension on the inside since the stock front coil spings are huge. you might want it for the back tho.
7.5 + 48 means 9mm less inside and 3mm more outside which isn't a huge improvement over stock.
If Rai-C doesnt need the driver ones, can i grab em instead?
is the front lower control arms interchangable with dc5 or EU?
yesss i need the driver side ones! ill grab em off ya johno! what did u want for em? :)
