how much is OEM? for oem the eu3 4door civic shares same as ep3 so i would get that. or dc5r too. im just reading around to see if omni is worth choosing over oem
cheers
lol didnt notice the hyperlink. thanks
Just a quick question guys. Do you know anywhere I can get the passenger air bag inflator from? I can't pass pink slip.
Can anyone recommend some alignment settings for hitting the track on the EP3?
Figures I was thinking of were:
Front:
-2 degrees camber
slight toe out (but I am unsure how many degree's)
Rear:
approx -1 to -1.5 degrees camber
0 toe
Height: will be about a 20mm gap between the tyre and guards
Mike, will you be going to Winton on the 24th? I will be!
Hey Julian, nah unfortunately I won't be ready in time. I'm aiming to get down to Sandown in the middle of October.
Good to hear your hitting the track though. It should be awesome!
Can anyone tell me where to buy the Cabin Filter for EP3?
I happen to check my today and its pretty dirty.. thank you~ :)
its time to service the ep3... just wondering which coolants would you recommend i use ? and whats a good injector cleaner?
For injectors you can get them clean professionally for around 25 bucks each. If your looking for an additive try the Nulon Total fuel system cleaner.
For the coolant are you planning to professionally flush the whole thing out or not? If not which colour is it? Dont mix different colour coolants together. Normally for coolants there are 2 main colours. Green or red. For green there will be 2 types, type a or b. Type a will be better since it has anti boil, anti rust and anti freeze while type b will only have anti boil? Red coolant are generally better than the green coolants. However i've also heard that honda started to make a blue coolant which is currently one of the best in the market. If you dont wanna spend that much stick with Nulon green coolant, ive been using it and it's running fine. If your interested just pm me cause i think i have some left.
