Running same coilovers. Only problem is that it doesn't go low enough!
what size tyres are you running? if i go lower, will solve my camber issue at the front but scrub more...
215/45/17 with -1.5 camber at the front and -2.1 camber at the rear. Still scrub in the rears under hard cornering but apart from that it's perfect. Could do with a little more low in the rears but the coilover on the passenger side has maxed out.
Where are you scrubbing? Camber doesn't really need to be 0 on the dot. Some negative camber may help if your scrubbing on the edge of the guard. Trim the splash guard? if you're game!
Haha, my mid pipe is now at least 10-15% flattened!
Ppl who did my alignment continued to drive the EP onto the hoist, even though it was scrapping. I even saw them trying to pull the car up by lifting it at the rear guards! Fail!!!
I can get over most large speed humps, sometimes I get a tiny scrape. I steer clear of the small short ones.
Hey guys.
Just got my ep3 mugen engine mounts installed by Dede at Top one auto. My car feels so different now! I can feel the difference in the acceleration its like a new car.
like i saw my left was 0.2 and right 0.08 at the front
but my steering pulls to the right even after allignment... like bit more torque steer to fight with. do you have like any aftermarket parts installed for your front like control arms or anything? i was told my wheels too thick width and height so lowering it will scrub but will fix the problem 50/50
The only speed humps I'm afraid of are the little splitted ones. Btw Mike, update your build thread already! What's plans? I get bored at work having nothing to read lol.
Hey guys. Have any of you guys changed LCA to f7 planning to do so, but just wondering if its a straight bolt on. Can I use the standard bolts. And what socket can I use to take of the standard bolts.
Yes you'll use the factory bolts. Probs be a 17 mm
