hey
do i need engineer certificate if i got b18c in to eg GLI?
is GLI is 1.5 or 1.6?
hey
gli = d15b7 = 1493cc
b18 = 1834cc
so that is more than 15%
(1 493 / 100) x 115 = 1716.95cc.....
1716cc is the largest increase in capacity you can go without engineering.
Look at a B16a engine perhaps , or spend more to engineer correct front and rear brakes to suit this larger engine capactiy increase.
15% capacity increase isn't true in vic, that's what i know.
just to be clear so vic peeps don't get confused with other state laws.
victorian laws state that if the engine is an increase in displacement, and the engine wasn't an option to the car when the manufacturer released the car then you will need an engineers certificate.
gli is 1.5
How about a Honda Civic Si put in a B18C7, need cert?
I doubt authorities would know the difference when they look at each motor. If you put a black cam cover on used oem mounts keep it stock looking they wouldn't have a clue.
guys everything i stated in the original reply is true. And the OP is in NSW so the +15% "optional engine" fact is correct.
Hang on...
Just checked B18C WIKI http://en.wikipedia.org/wiki/Honda_B_engine#B18C2
B18A/B18B = 1834cc
B18C/C1/C2/C7 etc = 1797cc
still exceeds D15B equipped cars :(
EG VTi/SI = d16y1/D16A9 = 1590cc
B18C = 1797cc
(1590 / 100) x 115 = 1828.5 :eek::eek::confused::confused::):)
EG6 didn't come out in AUS?
Honda Ballade 180i B18B (Never came out in AUS)
SO......... What now? :p
b18b's came out in the integra GSI's did they not?
And I don't know about this but VicRoads doesn't seem to specify that the manufacturer had to release the car with the alternative engine on a domestic market...so I think putting a B16A in an EG civic would be fine as it came standard in the Type R in Japan.
What you might also be able to do is install a B16A2 engine from the Del Sol etc into an EG because I've heard the stamp on those Aus delivered B16A2s don't actually have the "2" in some cases from what I've heard...it just says "B16A" (will need somebody to confirm this).
check again mate, i've been through it, got rejected from vicroads because my b18c7 was not an option to my ej8 from the car manufacturer being honda.
and if you still don't believe me it is extracted from here: http://www.vicroads.vic.gov.au/Home/...ehicleDetails/Quote:
Change of engine
1. Replacement engine is identical to the original engine, or is an option allowed by the manufacturer for the same model vehicle
The optional engine must be offered in Australia by the vehicle manufacturer as an option for that vehicle (or certified variants). The change of engine may be recorded by VicRoads provided that the registered operator or a motor mechanic, or dealer in that make of vehicle or an Automotive Engineer signs a declaration certifying the engine is optional for the vehicle model, and that all modifications made by the manufacturer for the same vehicle model with that optional engine have been completed.
You will need to attend a VicRoads Customer Service Centre to have the vehicle's engine inspected to confirm the new engine details. No appointment is required. You will also need to complete a Change of Vehicle Description form.
2. Replacement engine is not of a type offered by the vehicle manufacturer as an option for that vehicle or where alterations, or changes to the vehicle's frame or structure are made, and/or specially fabricated supports or structures are used
You will need to attend a VicRoads Customer Service Centre for an inspection of the vehicle to confirm the new engine details. You will also need to complete a Change of Vehicle Description form and provide VicRoads with:
* a VASS Approval Certificate from a VicRoads Vehicle Assessment Signatory
* an original receipt for the purchase of the engine as proof of ownership of the engine
Well I don't really need to check anything mate, I just just saying what I thought with the understanding that I could have been wrong.
And yeah but did the B18C7 come in the EJ8? What I was getting at is that I thought maybe you could do a B16A into an EG Civic as it was standard in the Civic Type R or whatever but according to your link it needs to be available to the model in Australia - not on an international scale.
The B18C7 would never be an option without a cert.
And relax, I believe you.
actually it wont work, lol how gay
Jesus this is still going on.
Ok here is exactly what it says on the VicRoads vehicle modifications website as Vampzzz has already linked. Just to clarify again, as it's been pointed out numerous times in here already and still hasn't sunk in to some. Note the bolded points.
Here's the information on VASS certification and basically how it is the new RES (Recognised Engineering Signatory) scheme.Quote:
Change of engine
You will need to attend a VicRoads Customer Service Centre to have the vehicle's engine inspected to confirm the new engine details. No appointment is required. You will also need to complete a Change of Vehicle Description form [PDF 24kb].
You will need to attend a VicRoads Customer Service Centre for an inspection of the vehicle to confirm the new engine details. You will also need to complete a Change of Vehicle Description form [PDF 24kb] and provide VicRoads with:
This means that yes, you will need certification to swap any B-series engine into an EG, a B18 into an EK or a K20A into a FD.
The next bit I'm goin to just quote myself from a previous discussion as I'm sure it has some relevance. Plus it will help clarify engine swaps for P-platers as it contains the national legislation for engine modifications.
still haven't got it registered yet as i don't have the funds to get an engineers atm.
it should work as its the same displacement, only when you increase the displacement will you need an engineers certificate. i'm not sure though, so if anyone can confirm?
nah, didn't mean it like that mate. just wanted to explain what i was saying. all good.
VASS approval stations pdf. Clicky
Technically, yes. But in this case you could almost guarantee that it would never be picked up through inspection. I also don't see why anyone would spend that much money on the engine swap when they could spend it on mods and see better results.
then i doubt a k20z to a k20a will be noticed?
B18C7's look identical to B18C's and they both have 'B18C' in the engine number.
K20Z2's look slightly different to K20A's and the engine number's contain different letters. I guess you could get away with it if you painted the rocker cover and changed the plastic intake cover but I still don't see this conversion being done due to the costs involved. I'd be more inclined to find out if a head conversion was possible. That way you'd retain the block stamp and theoretically it would be cheaper. I've slightly changed that post from before too just for future reference.
no worries mate, just wanted to make sure.
so in NSW you only need an engineers cert if the displacement increases by 15%?
As my first reply in this post states , entirely relevant as the OP is in NSW too.
Short answer
IF the car is replaced with an engine that is the same age or NEWER , an option for the chassis AND is within +15% increase , it is fine to install without need of engineering. You will have to change the engine number with the RTA.
b18 = 1834cc
Hey guys, just one question.
So wt should I do with the rego if I put a B16A2 in a EG Si?? (in Victoria)
Grifty - Yes
Key - Yes. It's not like you're being sent to the pits to be checked. Most of the people on that list will just be registered engineers at workshops around Vic. What's done to your car? If it's relatively stock it'll be fine. If you're unsure call one of them up and ask what's involved.
I'm up in Bris but when I went to get my car mod plated the engineer saw that I'd taken the air con out and said that with a nice big gap like that I should strap a snail onto it :p
They aren't a bunch of hardasses. They're just like your average mechanic.
Nah no mods done to it atm its pretty much stock, but i just wanted to know for future upgrades like a B18c later on
it'll be fine. Even if they were a hardass, they'd only care about is emissions as you're going in for engine conversion engineering
So if I drop at B18C7 in my Honda Civic Si, can I drive around with it having no engineer cert yet and not reg? What happens if I run into the cops?
If you drive around with an unregistered car prepare to have the car impounded, cop a massive fine and enough points to probably lose your license if caught.
http://www.rta.nsw.gov.au/registrati...ed.html?rlid=2Quote:
Driving an unregistered and uninsured vehicle is also an offence attracting on the spot infringement notice fines of at least $972 ($486 for being unregistered and $486 for being uninsured). If the matter goes to court, the maximum fine is $2200 for driving unregistered and $5500 for driving uninsured.
Why not just rego it with stock engine and then drop the B18C7 into it, then next time pink slip is due u would of have saved up enough for an engineers cert.
Having an engine in a car that is registered with another engine will have you ending up with the same penalty if found out by the authorities. It's got nothing to do with rego renewal. You're meant to notify the department of transport as soon as the engine is swapped.
It doesn't matter if it excedes the 1.5 it's based on the model which means any EG is based on 1.6L and 15% above that ..
Read it properly its the same with wheels .. If a base model has 15s but the top model had 18" you on your base model can go up to 21" legally ..
You need to understand and read the laws properly ..
B20 or above including k swap need cert ..
B16 B18 are fine for any eg including the 1.3carby and should just need a blue slip cleared ..
Shit old thread stupid tapatalk showed it as new
Just letting you know Victoria's allowed power increase is 20%
http://www.vicroads.vic.gov.au/NR/rd...orvehicles.pdf
Page 3
