I have been inspired by many car fans and builds such as BYP civic, JDM yard civic, Js Racing DC5R etc to name a few which has motivated me to mod my fn2r that i have recently purchased. Hence I would like to share my experiences on my build on this forum.
Firstly, although the stock rims complement the looks of the car, it is ridiculously heavy – weighted at approximately 20kg including tyres per corner! The rims/tyres alone weigh approx 80kg all up! Despite the weight of the rims, the stock tyres (Bridgestone Potenza RE050A) offer extremely good grip for street tyres. To pursue my path of weight reduction, I have purchased a set of Rays CE28Ns in gloss black (17x7.5 +43 offset) with a set of Yokohama Advan A048 semi slicks (225/45/17) for track and a set of Bridgestone Potenza Adrenalins RE001 for the street.
http://img263.imageshack.us/img263/9489/img8683v.jpg
http://img811.imageshack.us/img811/1271/img8685.jpg
The ce28ns are impressively light-weight, approximately 5kg per corner! Which is a 5kg weight reduction from the stock rims which weight up approx 10kg each without tyres. From this I have already reduced 20kg all up of unsprung mass! To complement the rims I have also purchased a set of Rays Duralumin nuts After driving the car, I could feel a day and night difference in driveability. The car requires less force and due to the less mass the car accelerates a lot faster, it seems like there is more available torque at every gear throughout the entire rev range. Furthermore, braking is also improved as it requires less braking force and due to the smaller diameter it absorbs shock slightly better. The semi slicks sound awesome! And they are effing grippy, it is almost impossible to lose traction driving these on the streets, the car feels like it is on rails and stick to the road like it should!
http://img153.imageshack.us/img153/5517/img8682.jpg
Secondly, I find that the stock intake system is very restrictive and after pulling it apart you will understand what I mean! It is massive and also weighs a fair bit...
http://img514.imageshack.us/img514/8408/img8695t.jpg
http://img815.imageshack.us/img815/5210/img8693.jpg
Stock Intake System
http://img808.imageshack.us/img808/2420/img8704.jpg
Stock Air Box
http://img295.imageshack.us/img295/5567/img8706a.jpg
Stock Resonator
http://img15.imageshack.us/img15/7193/img8707t.jpg
http://img687.imageshack.us/img687/5791/img8692a.jpg
I wanted a cold air intake to give me better gains and induction sound. After doing much research, I was tossing up against either the gruppeM vs Injen intake. Effectively the gruppeM intake is a short ram intake using a K&N pod filter with a large carbon fiber scoop, used to ram air into the filter – for the price of this intake ($1000+) i could not justify purchasing it, people had also questioned whether the ram/scoop effect was effective or not as the scoop lies under the bonnet and draws air from the grill however some argue that the radiator was in the way and would not allow efficient air flow. My second option was injen, this intake is a true cold air intake that draws fresh air from the left hand side near the foglight/wheel arch. In the end, I chose the injen intake because many dynos results showed similar results to the gruppeM and it cost less than half the price!
Injen have designed a revised intake for the fn2 which I believe gives better gains as they have enlarged the diameter of piping, filter and use a different mounting bracket. However, there were a few hiccups to installing this intake and I would like to give credit to the JDM yard crew who had spent a lot of time with me to ensure this intake fitted perfectly (pm me if you need details). I also bypassed the throttle body coolant line and as result the intake manifold is a lot cooler even after a hard drive, i can comfortably place my hands over the manifold whereas before it can get extremely hot especially due to our small engine bay. In conclusion, the injen intake delivers good gains throughout the rev range (dynos show a positive +6hp net gain) and is much more responsive with no flat spots at all. The foglight however seems to cover up the area of the filter, so i am looking into removing the foglight and making my own ram or scoop to deliver more direct air. Another alternative is to use the mugen air garnish but it does cost a small fortune...
Injen Cold Air Intake
http://img715.imageshack.us/img715/9639/img8710.jpg
Piping and hoses removed for tb coolant bypass
http://img18.imageshack.us/img18/4858/img8711d.jpg
Hopefully sometime I get the chance to track the car as is before I make further developments, next I will be looking further into upgrading suspension and brakes before I chase more power so stay tuned!
