hey guys. ive got a set of R32 GTR injectors (440cc) just wondering if any1 can tell me if they will fit straight into a B18c Skunk2 manifold. i no i have 2 change the clips. will also b running skunk2 rail.
thanks in advance:thumbsup:
Chubbs, Hondas run high impedence injectors and I'm pretty sure GTR (RB26) run low. You would need to run a resistor box. As for fitting, since you have them, just try :)
hey thanks george so if i follow this than i shouldnt have a problem
http://www.c-speedracing.com/howto/r...box_wiring.php
You can use toyota ones easily picked up for $20. Run them 2 x 2.
You can also just get some K series which should be ok, unless u ruuning big boost???? huh???
digging 4 info huh haha. no boost still trying 2 finish the teg
why do you need to upgrade to bigger injectors ?... Ever thought of S2000 ones? They seem to work well and have higher CC over B series.
I have a cheap used set if your keen to try out.
larger cams and pistons. had a gtr and needed 2 change injectors on that so now have a spare set just sitting there. may as well use them if i can.
My friend is running R32 GTR injectors on his B16A turbo setup. I'm pretty sure they fit well with only minor adjustment (I can't remember what).
I'll SMS him tomorrow and link him this thread so he can explain. Might not be too disimilar to B18 rail setup.
R32 GTR 440cc injectors will work with a bit work on Obd0 ecu electric system but Won't on anything obd1 on wards,
Main reason as Nepolian said
Add more info to Nepolian quote
OBD1 and newer are high impedence injectors
while OBD0 are Low impedence injectors
here a link that was show to me when i got told there a different between the the between the OBD0 from ED9 D16a8 crx, DA9 Interga B18a, EF8 B16a1 etc to the Obd1 and onward used in EG civic's, DC2 Interga's and accord etc
Hope this post help most people
http://hondaswap.com/general-tech-ar...jectors-30347/
then i shouldnt have a problem if i wire up a resistor box
wire up a resistor box sound to me as waste of time as there alot new high impedence injectors out there new for good price
i recommend try the S2000 injectors or source some higher stock injectors which are high impedence injectors as it would be alot easier clip straight in or solder in wire new injector plugs to suit you injectors (most new aftermarket injector set come with pigtail injector connectors)
Really you don't need much more than just stock injectors if you still run N/a
If you find your injector are maxing out when you are tuning your engine that when i would think about injectors
try look on ebay for set from the usa with our good US dollar
Why do you want to use R32 GTR 440cc injectors anyway? Is price? or you have them there as said before?
just trying 2 save a few $$$ and if i can do smething simple like wire in a box, i dnt c any point in spending more money on smething i already have.
thats if they fit
Just a quick note, careful with the R32 injectors,
They're getting pretty old now (20yr old)& they often leak from the side of the inj body
(Near the yellow plastic)
Edit: Also vs RB 440's, you'll get better results using either ID injectors or up the fuel pressure & use the std injectors(pump ®)
If the pump is up to it, no problem.
High pressure walbro is usually enough to do the job.
Rail pressure is around 65-70 psi (vacuum disconnected) Std fuel pressure is 43.5psi
This will support around 145-150kw @ wheels on 98RON pump fuel.
Be sure to have the injectors checked & cleaned.
thanks 4 the advice.
running a walbro 255 and looking 4 round the 130-140kw
would it b a good idea 2 run slightly bigger braided fuel lines?
for the hassles and effort, just get new FIC's injectors. They fit perfectly and work great!
