has anyone encounted any vibration when the car hits 2000 revs???
yes i do. i only started noticing it not too long ago. im thinking its just because when i attached my cai it's a little bit crooked. im thinking its just got something to do with the piping rubbing the car or something.
Moved to the Euro section and fixed your vague title.
I had vibration at 2100rpm when my car was fully stock.
mine never stay long at 2k RPM.... :p
but my doors got rattling/vibrating sound at the door lock knob area...
Different RPM's vibrate different parts of the car, and 2000rpm seems to be the RPM that vibrates the car the most. It happens on mine too so it seems normal for all euros.
tron, if you hear rattling from the door, you just need to remove the window switch assembly and apply some tape around the switch housings. I think its the main drivers window switch that rattles around
At 2000-2100rpm, well in my case at least, it is not vibrating because of the interior. There seems to be a sort of resonance with the intake and maybe the exhaust system that causes resonance vibration throughout. Resonance vibration sounds very different to rattling. I don't hear it anymore with my current intake, so let's see if the Euro owners who have CAIs also have this problem.
Tony1234, do you have this problem with your Icebox (and stock header)?
[QUOTE=tron, if you hear rattling from the door, you just need to remove the window switch assembly and apply some tape around the switch housings. I think its the main drivers window switch that rattles around[/QUOTE]
I had that rattling as well but i found it came from the electric mirror switch.Did the same fix that Eurodude did and all is quiet now.:)
I got an Injen CAI and it rattles around 2000rpm's. :thumbsup: or should it be :thumbdwn:
Havent started sound deadening my car yet... so just living with it..... got a box of dynamat extreme and a piece of dynamat extremeliner for the car already. Also got a piece of insuflex for the door. Thinking maybe getting a can of Cascade Quietkote to spary the door panel before sticking the insuflex.
Mine does the same, its alot more noticeable when in wrong gear.
^ yeah thats the one. If they magnify the vibrations, why use them?
It's to stop engine movement to reduce wheel hop. Like solid engine mounts. Total opposite of what you want to use it for.
On my Euro, it makes such a vibration that when the A/C comes on at idle, it sounds like a dying diesel engine. BTW, coming to wakefield on saturday?
Read this thread...
http://www.ozhonda.com/forum/showthread.php?t=58673
My one got vibration noise from the left front window (especially when going over small bumps like the patches on the road cracks), sounds like the glass is not securely positioned. Weird thing is that the noise disappears when I wine down the window just a little bit. Maybe I am just too fussy or maybe the engin is just too damn quite.
Also got a question about running-in, not sure if I should ask here or start another thread.
Both euro and this forum is new to me, so solute to seniors!:honda:
When I first installed my Icebox I gained some vibration at around the 2KRPM mark. Several months later, I re-tightened the screws around the box (which originally didn't fit perfectly) and now the noise is gone entirely.
I suspect that prior to this the airbox had been sucking air in from a corner of the box itself.
Since sealing the airbox properly, the setup is much quieter in all aspects of operation now (not just NVH). There is also much better low-down torque available. I can actually drive the car around in 4th gear at low speeds without any dramas whatsoever (only if I'm lazy or something else is going on in the car).
Thanks aaronng! always thought it's the engin that needs the run-in.
The dealer told me to avoid staying on one gear or use cruise control on highways. is this for the sake of gear box or engin? If for the engin, wouldn't the idle warming up be bad as well then, since the RPM stays the same when idle? mine is 600k now, is it too late to run hard to sit the ring properly? kinda did one long run on highway for about 40 mins on pretty much the 6th gear (it's just hard to use anything lower than 5th gear with 120k/h speed limit). how bad would it be? :(
decided on euro when the dealer hit VTEC during the test drive. just sounds sweet,looking forward to hitting the red line :)
:) quick reply indeed, still up apparently :) Thanks for your advice, yes, what's done is done and I should just think this way: even wasn't run in the best but with today's high manufacturing standards, it won't be a disaster anyway!
I find that the hook that holds the bonnet down when closed is not tight enough and allows the bonnet to move up and down a few mms causing a rattling sound at low rpms and take off. I have fixed this sound and a few other euro friends of mine by putting some electric tape around the hook to make it tight enough when closed. You can replicate this sound easily by pressing down on the front of ur bonnet and releasing again repeatedly, I'm pretty sure all Euros have this problem, and it would be the first thing I would fix before other rattles because it took me a while to realise that the noise was actually from outside.
Old thread but as some may know I have the vibration above 2000rpm too butcan't find the other thread, it's like buckled wheels but under load only.
Took it to Honda yesterday but they still have my car to fix the 2 recalls on the Euro. Talked to the tech and he recons its the CV joint, lets see if he is right, somehow I think it is Head related.
i would have either considered lugs or hub problem/ wheel bearing.
Or
Your choice of CV joint.
When is the last time you balanced and aligned your wheels?
Btw what sort of vibration is it jerky bumpy sort of vibrationg or constant droney? and what mods on your euro if any.
A CV joint would give a knocking sound. Not really a vibration. And my Euro had this 2000rpm vibration from new.
I seem to find it's more noticeable when going down a hill with my foot completely off the accelerator pedal at 2000RPM as opposed to going up a hill at 2000RPM. I don't know why the difference but.
never is cause car is always at few hundred rpm when idling.
My wheels are good, happens with other mags I put too. Got it back and had about 15 fault codes which can only be cleared by their computer not by disconnecting the battery, so they cleared them and they didn't fix the vibration which only happens under load not when just rolling or cruising. They claim it could be the drive shaft that flexes in the joint at the gearbox, not the actual CV joint but can only test it by putting new CV's, I will go talk to the CV specialist and see what he thinks. Feels like buckled wheels when under load above 2000rpm and usually above 70 or so K's, I know it is not my wheels, coils, injectors, spark plugs.
Also I asked why my engine is kinda vibrating at idle and he said most Euros do that above 120000k's and it may be due to the engine mounts stiffening up over time, other than that he knows it is a problem that Honda has no answers for.
Honda charged $46 fr the diagnosis and testing, not too bad asI was expecting more, also got the recall jobs done while there.
It is a 4-cylinder engine, of course there will be some vibration at idle!
your air filter is what keeps it clean.
but it still builds up dirt from the fumes and dirt particles.
if your worried that your butterfly in the TB is going to get jammed then you can clean it yourself.
rofl but don't waste your money or get it done on your next service.
Seems to be a problem on the CU2 too.
http://www.acura-cl.com/forums/showt...php?p=10664274
The black rubber bits that rest against the bonnet can be adjusted up and down they are both just above the headlight, I moved mine so they were about a 1mm higher to eliminate the hood chatter/rattle.
Funny thing is I replaced all the clips and the noise didnt go away, so did abit of exploration and came up with this method.
Well know i know what they are called "bump stops"
Thanks guys for that advice. I'll give that a try. I also read in the repair manual that the bonnet can be adjusted to move left or right or forwards or backwards. So I'll get the alignment checked to make sure its a plush fit. My vibration is most noticable on a cold start when the idle is higher than when the car is warmed up.
you do it just enough to sit flush.
I turned my stops clockwise to fully lower them. Now the bonnet sits firmly with no give in the latch.
FYI, Finally sorted out the vibration problemat 2000rpm usually at higher speeds and only under load.
I have been told it is very common for Euros when they get on in K's. The problem is the inner joint on the drive shaft. I got mine replaced and cost me under $100 each end as I took them out and gave it to the CV joint specialist. Happy nowI don't have a vibration anymore as if my wheels were not bolted up tight:)
Another problem with euros with higher k's is a stretched timing chain which will give you rough idle and sometime fault codes.
First Honda said it may be the shafts, then Hanny's who said the same thing, it also happens to S2000's. I took them out cause it was so dangerous and took it to A&L driveshafts in Campsie. He told me it is common on Euros and showed me where it was damaged after cleaning the grease out of the inner joint.
At first it was a small vibration and slowly got worse untill I couldn't even go uphill on freeways at normal speed, had to travel at 60klm and looked like a D!@k He@d.
Looks like I will have to get myself a spare set of driveshafts. :(
Mine is still minor, only at freeway speeds and it is very subtle in the form of steering wheel vibration. I have ridden in another Euro where the car goes BANGBANGBANGBANG once it exceeds a particular speed and strong throttle is applied.
I found this article that relates to the Accord v6. I'm sure the exhaust set up is different in the two cars, however, is it possible that a damaged or deformed exhaust pipe mounting bracket could be the culprit in our cars?
