What front red honda badge will fit the euro R grille for a 2003 euro? thanks
the TypeR badge off an EP3 civic...
if you need the part number, use the search function and find my previous posts about it... :)
EDIT:
i searched it myself, heres the link:
http://www.ozhonda.com/forum/showthr...d+badge&page=2
http://i239.photobucket.com/albums/f...F1520Small.jpg
thanks mate your a legend, so this fits the normal front grille and the euro R grille?
They should be the same mate, i fitted my H badge from my normal grill onto my euro r grill
rep'd
I think your car's red badges are the bees knees and the ducks nuts. But I mostly like your blank number plates. Now these would really add lots of km/h to your top speed. Think about it; no number, no speeding fines. Better than any turbocharger in practice.
PS Did you know that the ACT can never become a State of Australia.
Hey,
was out in the garage today sorting out parts for my K20Z cylinder head swap.. and found alot of the packaging/old parts off my car... i didnt know where to post it, but i made up a list of useful part numbers for those interested, hope this helps some people :)
Description Part Number
EuroR Conversion Parts
03-05 EuroR front grille 71122-SEA-901ZJ*
03-05 bonnet trim (replaces chrome) 75120-SEA-R01ZE*
CL7 front grille EuroR emblem 75732-SEA-R01
EuroR radiator bulkhead cover 71123-SEA-901
Rear EuroR badge 75731-SEA-R01
EP3R Front red H badge 75700-S9A-600
DC5R Rear red H badge 75701-S6M-Z01
FN2R remote control red H backing 35114-S6M-Q11
CL7 EuroR intake manifold 17100-RBC-J00
CL7 EuroR intake manifold cover 17121-RRB-A00
CL7 EuroR rocker cover 12310-PRC-505
DC5R red engraved gearknob 54102-S6M-R00
*Note: Part Numbers for Satin Silver (replace last letter for other colours)
Lubricants, Fluids, etc
OEM Engine Oil - 5L B1767
OEM Oil Filter 15400-RTA-003
OEM Manual Transmission Fluid 06 B1710
OEM Liquid Gasket 08C70-K0334M or 08C70- X0331S
OEM Coolant - 5L B1801 (Type2)
OEM Cabin air cleaner element 80292-SDC-A01
OEM Fuel filter 16010-SDC-E01
Tools
Crank Pulley removal handle 07JAB-0010200
Crank Pulley removal socket 07JAB-0010400
Cam Chain Case handle 07749-0010000
Cam Chain Case driver attachment 07746-0010400
Non Honda Parts
Cometic K24 high compression headgasket C4311-027
Cometic K24 standard compression headgasket C4311-030
ARP K20/K24 headstuds 208-4701
Gates Micro-V belt for UR pulleys K070683
Power Rev Racing TB thermal gasket P106
Power Rev Racing TB Spacer (black) P305B
NGK Iridium spark plugs IZFR6K11
*AMENDED 1st NOV 08 - DC5R Rear badge number was incorrect, correct part# added
Soooo close.....
Fuel filter is :16010 SDC E01 :thumbsup:
Air filter for anyone that needs one :17220 RAA A01
RHF door lock actuator :72115 SDA A01
LHF door lock actuator : 72155 SDA A01
There is also a replacement kit available now for the rear sway bar link pins, aparrently they are thicker so they dont snap like the old one's used to, dunno the part number off the top of me head, 06360 SDA A01 maybe????
lol thats about all that goes wrong with the CL's, fuggen great car!
06360 is a recall part number.
havent seen any swaybar link pins kit recall for CL9 tho.
as far as im aware yes, the badges are the exact same size. if you want to be 100% the measurements are earlier in this thread...
this one im 100% on, i know because i have MY07 (same as MY06) boot on my car! :) so yes, it will fit perfectly!
hey dude just curious got my euro R grille today in the mail, what screws do you need to use to stick the bottom trim onto the grille? and does anyone know how to get rid of that chrome trim at the top of the grille/bonnet on a stock euro?
i think my grille came with some small screws that hold that bottom strip onto the grille... if urs didnt, just go to hardware store and get some small self tapping screws.. make sure theyre not too long or theyll pierce the grille!
as for the chrome bonnet strip, u can order new ones, (i can get you the part no. specific to your paint colour) or easiest way is to respray it yourself :)
or do what im doing, and going to get a MY07 bonnet :D
i want a CF bonnet :( with scoops so my SRI can BREATHE!!
hahahhaha goodluck on that, so much money to buy and ship one over and then you may or may not get stuffed by the cops if you haven't got it engineered either.
well you don't really need to take off the bumper.
as long as your good at using your hands all you do is take off the radiator cover.
1. remove the plastic clips without breaking them. flat head screw driver and wriggle the clips gently *not plucking them out*
2. take radiator cover off
3. use your hands to feel the stock grill and you can feel 4 of those plastic clips underneath it, use flat head and pry them out gently as you did with radiator cover clips.
4. put your grill on and if you need any other ways of mounting then might have to diy but should be pretty easy.
5. if you need help with removing bumper please don't hesitate to search or ask us on ozhonda for DIY by matell or ....... can't remember the other guys name who recently installed and did a DIY on sports grill.
hahahhaha.
But back on topic regarding the red badges, although its nice and all, the bad thing is because they are relatively rare, the risk of getting badged is high. Same goes for euro-r badges as well...thats y im reluctant. Also cos i cant afford them atm lol :(
rofl...man u spent almost ~$200 on the euroR badges alone!? lol
or perhaps u got them at a better price? :p
But anyhow, it does finish the car nicely but too bad some low lives decide that they try get a free badge off someone elses car. I've heard the stock accord euro badges been taken...so wat are the chances of being badged with red H and euroR badges lol...but then again, ppl in canberra are probly nicer :p
installed the grille, pretty dam easy i have to say, just a question i cant figure out how to remove the chrome bonnet trim thingy like above the grille.. i want to get it painted night hawk black... and should i take it to a shop to get it professionaly painted or should i get some spray primer and spray night hawk black LOL and DIY?
just undo the four 10mm nuts underneath it (open the bonnet and look up - theyre kinda hidden recessed in abit) then pull the trim directly outwards from the bonnet, there is a clip holding it there and itll snap if you try pull down... i did mine DIY, its easy to do, just sand down, use plastic primer, colour it, then clear coat it... i have to redo mine again, i didnt match the colour close enough :( lol damn 30 different kinds of silver!
anyone know if the JDM FD2R or DC5R front red honda badges will fit the 06 euro sport grille?
