Originally Posted by
preludacris
dude everybody knows when tuning a car, that u focus on the b4 dyno run , and after dyno run - how much power increased, the shape of the curve, and AF ratio. A lot of differnt dyno's will read different power figures.
If his car was tuned on a higher reading dyno, and gained 10kw, and then later went on a different dyno and the peak rating was lower. he Still gained 10kw ...period. You cannot compare differnt dyno readings with each other. only as a general figure, as some will read more accurately than others, the Temperature may be diff etc.
