Mayb you've got a blown oil spark plug/cam seal.
Causing it to burn and blow white smoke..
So many different opinions. What do
a solution that will answer your question as to whether its worn and burning oil or not:
go to a shop that has a leakdown tester and have a leakdown test done.
then you should get your answer. you'll pretty much just get guess after guess on forums until you either do some testing or get someone else to do some testing.
Yup - diagnosing via internet is guesswork and is like checking the net for a medical diagnosis - the only real answer is going to be from the guy that slips on the rubber glove and does some probing.
Cool ill snoop around in my local area if anyone does it....
Any recommendations as to a spot i should go to? Im in S.E Burbs
Thanks for all the help so far guys! :)
So i made some phone calls in my local area and sadly not one could do a compression test....
But i've had some input on several occassions that it most likely is the valve stem seal, due to the fact that "it only smokes on start and doesnt smoke when the engine has warmed up"
Pressure test. Get one done at a radiator joint. They can also do a litmus test on your coolant to see if it has carbon emissions in it which aren't always visible to the eye.
Compression test should be manageable at any shop lol.
Drive to Nunawading. Straight down Springvale road. Find a place called Mideast Radiators near Maroondah highway.
If you want I'll meet up with you and take you.
make sure you get a leakdown test, a compression test is no replacement for a leakdown. compression test will give you an idea as to whether its sealing reasonably ok, but the leakdown will actually tell you how much is getting out and where.
normally the symptoms for bad valve seals will be smoke at high RPM and under load, does not completely go away when warmed up. valve guides is another culprit in B series but don't jump to conclusions until you can prove what's causing it.
