Hey Guys
I’m just about ready to start putting the turbo on to my car after about 9 months of collecting all of the parts and I thought some of you might be interested in the log manifold I made for my car, I had to make my own manifold because of the engine and car I have any other manifold would not have fitted in.
Heres the butt weld fittings (steampipe) I started with
First I cut the pieces down to fit and used an old gasket to get the port spacing correct
Here it is all welded together and the mount for the flange started
Before it was fully welded together I ported it all out on the inside to remove the lips from the fittings not lining up perfectly.
And this is the test fit before it was fully welded up.
All I have left to do on it now is a little bit more porting around the flanges and it’s ready to go.
Hope yous like it!
Cheers
Luke
