Only u se BKR6e-11 if your NA !! use BKR7r-11 if ya have a turbo honda, replace them every 5000km and your will never run better !!!
All this talk about platinum and special plugs blah blah is all crap coper is the worlds BEST conductor even better than gold its just doesn’t last as long... so simply replace them more often. BKR plugs are around 2.5$ so it won't break the bank buying some every few weeks...
Don’t believe all the rice crap, regarding special plugs costing like 20$ a plug !! HA HA don’t be lazy change back to copper and replace them more often.
Iridium’s are still a waste of money go COPER !! and replace them more often !! sure a iridium plug might last 100,000 km but pff when does it stop working at its best !! hmm after 5000km !
Regards James
so they stop working their best after 5,000km's?
If they provide such little benefit after 5,000km's then why are the on the market?
Why does some of the top drag cars use them?
Show me a top drag cat that use's Iridium’s, there electrode's are so small when heated up especially in racing and even on the dyno !!! they tend to break and cause massive engine damage !! iv seen this happen first hand !!
Product code is NGK BKR6e-11 (for NA) or NGK BKR7e-11 if ya boosted or drive hard around a race track.
Above 15psi of boost I recommend RS-8 plug range from NGK.
Again all these plugs are coper plugs !! coper the best known conductor of electricity. Why would you wanta use anything else !!
ummm factory specs state DENSO or NGK. What plugs u require should either be in the user manual/print on cambelt cover OR just rock upto a honda dealer and give em ur car model/year. ONLY use DENSO or NGK.
[TNT] Team No Traction - Cos No Traction Is Underrated
i heard the NGK's alone can add about 10-25kw... true or false?
BKR6e-11..?? is that NGK? and do u mean $$2.50 thats pretty cheap!.. and yeah james where can we get these? what would happen if i didnt feel like changing them after 5000km haha? bad or good? thanks guys for all the input!
