DNY*BOY: I take it that you're using external HDD that is powered through the USB adapter?
I've got 2x external hard drives but they both have 240v power plugs (to power them) as well as USB cables (for connectivity).
Is the ext HDD powered through the USB port? Wouldn't that pull alot of power through that port!? :|
generally the 3.5" externals are 240v powered but the 2.5" drives are usb powered - however the port on the HU may not be powered and in any case, some drives (eg my 80gb maxtor) require TWO powered usb ports to run (stupid i know)
it does work, but as someone correctly pointed out, in some cases there is a limit to the number of folders that can be read
