if its hooked correctly one would assume the back firing and more up top would be excess carbon or oil vapor in the combustion mix - have you replaced your PCV of recent Luke ? If its still the old honda item from no doubt new its probably in dire need of a replacement
I notice the drain fitting from the bottom has been added to the side where you've fitted the weld on 3/8 NPT bung.
So what's in the bottom now & where does it go?
TODA Performance Australia Pty Ltd TODA Racing - FIGHTEX - MFactory - HALTECH - EXEDY Race engines, Dyno tuning, Licenced workshop, Parts.
P:0401869524 email: toda@todaracing.com.au
Just used a better plug with an 0-ring built onto it but its still blocked off
PCV is removed or drilled out for this setup... I've drilled my out
161.4KW ATW Tuned By TODA EG5 JDM B16A SiR-II TURBO
shouldn't make any difference if your PCV is drill or not. Its prob better to have a good PCV so the air doesn't go back into the head, but from the head side it should be pressurised and the intake side depressurised.
ok i think i know what's wrong. Luke, the Blue line in the picture is supose to goto the PCV, looking from your setup you've got it to the intake manifold, so your leaking boost thru your catch can. That's where the problem is coming from.
I believe the PCV is lower near the block, someone got a pick of the PCV location?
Na that manifold intake is blocked off
I think the problems fixed anyway...
Replaced the pre-turbo to rocker cover with a slightly bigger hosing and I didn't have any problems on the way home but I'll wait till later tonight to really hit it..
I'm going to put the stock PCV valve back as Limbo mentioned
yeah the breather on top of the catch can was not actually going to vent atomphere. its more just the fact that NSW cops love to pick on things they don't understand.
Luke being Luke, wants everything within the legal system even when some of them don't make sense
Anyways, i've got a new idea of hiding the filter on the catch can now
