Page 1 of 2 12 LastLast
Results 1 to 12 of 15
    the lower bar is the standard tiebar. It does something. You should reconsider installing the beaks....
    Anyway , to install you must have the lower control arms free IE loose (ends disconnected and shock disconnected and you simply take out the longer 14mm headed bolt , place the tiebar on then reapply the 14mm bolts.
    Mar 2008
    treasury casino
    150 bus
    Quote Originally Posted by xQuizit View Post
    ohok thanks... btw howcome you think i shuld reconsider? ye i just consider it as bling bling lol
    ill assume you are owner of integra R, he is saying reconsider, because they come with this standard, just looks a bit different. the bar that is in the picture does exact same thing, so inface you are just weighting down the car lol.
    but i think it looks cool, i had one on my eg.
    if you can be bothered installing it, then go for it. it also scrapes everywere. none the less its a very cool part.
    s tune Array
    Jun 2005
    ADL
    99 DC2 sold :(
    Yeah basically you don't need it on the R, when I fitted mine I removed the lower bolt on the frames of the ABS line on each side of the subframe, took the bracket to the work bench and used a grinder to cut away the part which fouled the tie bar and reattached the brackets slightly re-routing the ABS line underneath the tie bar mounts.
    Pic added: perhaps I should re-route it over the tie bar instead
  8. #8
    Mar 2008
    treasury casino
    150 bus
    so are you gonna install it or not ? looks cool but lol. i installed it myself at home so not hard either but for your car looks different
  9. #9
  10. #10
    Mar 2008
    treasury casino
    150 bus
    i dont remeber moving any of those wires out the way, all i did was take out those two bolts and line it up and put them back in. i did some other wierd shit, but you dont need to. for some reason i took out sways and pretty much everything else lol.
    btw if your a bit confused, were the green arrow is pointing that thing does same as beaks
  11. #11
  12. #12
    Jun 2004
    syd
    ek
    maybe because his car is a type R
    12.949 @ 107.71mph
    2.063 60ft on Advan AD08
    EKK20A 142.9kw on 98ron
    its not called stance if you're on spacers..
