do you know how to remove the fender?
there are 6 bolts (10mm) to undo to take out the fender.
3 bolts in engine bay
2 bolts under side skirt
to remove side skirt, there are around 4 screws holding the skirts and some clips
undo the screws from bottom of side skirt, and push the skirt to the side to take
them off (dont pull it. push sideways, different type of clips).
1 bolt behind your door.
after that then.. you know what to do la.
S P A M | W O R K S
