i am using 16 ATM and camber at front is -1 and rear is -1.5
so if i change to 15 i need change rear to 0?
Nah you should be fine with those settings. I was just saying that if you had 0 degrees camber at the rear you might have to roll because +35 is slightly lower offset than stock but with your current camber you will be fine.
You should be okay to just bolt the wheels on and go .
