hi i got ek with k-swap with the eg crossmember and LCA's and i put buddy club p1 4 piston front calipers(come off an eg) with 300mm slotted rotors on and now wen i turn the rotor touches the LCA and is grinding away wen the car is on a hoist or the wheels are off the ground there is a 7mm gap between the rotor and the LCA but when its on the ground its barely 1mm i cant figure out which part is moving the LCA or the hub. any advice any1 could offer or any tests i could do to figure it out would b much appreciated thanks alot
