Results 1 to 12 of 17
    Jan 2009
    VTi-R
    Post Nulon engine oil flush
    Any one tried using the nulon engine oil flush? I have a Civic EK4 that I am tempted to use a flush before I change the oil. Is it safe or necessary? I purchased this car not that long ago and previous owner looked after it well. It has travelled 110,000 kms with full log book history. I am inteding to use the FEO oil on it.
    Nov 2008
    Melb East Side Yo!!
    Teggy, Spada Vt
    engine oil flush is simple and esy to use. i use it, used to use a different brand (dont remember name) but all it does is emulsify the oil and when you flush it out most of the oil stuck onto your internals come off as well. engine flush runs on the same theory as liquid soap. put on greasy stains and then scrub away with ease.
    its a good product for a fussy owner and i am one of them. before flushing run the porduct in your car for a good 15 mins. i actually take the car for a run with the product in, to ensure it spreads around before a oil flush. make sure after flushing your oil use some fresh oil and flush it again i.e pour in the fresh oil and let drain out. 1/2 a liter is good for this task. this is just to cleanse your engine. but thats what i do not really nessary.
    hope this helps
    -=¤§ ń Ĩ ģ ĥ ţ Ŵ ő Ł F §¤=- ™
    info worth the rep point?
    WIFE AND DOG MISSING!!!
    REWARD FOR DOG
    I wouldn't flush it unless there was long intervals between oil changes previously. If the previous owner serviced his car religiously, then I don't see the need to flush it.
    Who's your messiah now!
    You know you want too... Array
    Sep 2005
    DC2R + VT750c2
    i see your point about taking it for a run, but i think the recommendation is to let it idle. The reason for this is that it breaks down the protective qualities of oil...
    Idling for 15 minutes will get the flush everywhere you need it man.
    - not removed by choice! - waiting for the next update to the saga
    http://www.ozhonda.com/forum/profile...=ignore&u=6316
    And then if your engine is really filthy a strong detergent can move grunge from places where it's stable and benign to places where it isn't, i.e. liberated grunge can create a huge filth load in the oil that may be enough to clog the filter and then you can have very dirty oil being pumped unfiltered through the bearings etc. This is not a good thing even if for only a relatively short while.
    A good e.g. is old air cooled VW engines that would / will grunge up big time if oil changes are not regular, so many neglected VW engines can carry a huge amount of gunk on internal surfaces. When the oil is finally changed, if the crankcase is flushed with a chemical cleaner or a high detergent oil is used (and most modern engine oils have a fairly strong detergent action) then it isn't uncommon for the engine to abruptly die because of the liberated debris in the oil.
    Most crankcase engine muck adheres in places where it's not an issue because it isn't on a working surface and can safely be left there. The one place where it can be a real issue is when it builds up on piston rings and ring lands, which can cause ring sticking resulting in compression loss.
    I wouldn't use any sort of engine flush if the engine already has any significant grunge build up (much safer sitting where it is), but if the engine is already fairly clean it's probably safe. Personally I use an oil with a very high detergent content which cleans the engine less aggressively than a proprietary chemical flush, but does so all the time and helps prevent build up in the first place. The oil I use is a quality diesel oil (which are very high detergent), and work very nicely in petrol engines.
    Well looked after Honda engine tend to be quite clean (unlike some Toyota engines), but it really is important to change oil regularly to avoid sludge.
    Feb 2008
    Gc subaru
    i read somewhere its a gimmik
    Quote oh dear ****ing lawd. my d*ck did more than move. it jumped out of my pants, and tore the fly open....
    TRIPLE OG Array
    Aug 2004
    MEL/JPN
    b18c crx/that's
    not really man. most people don't realise how much builds up in there
    even on newer cars its a good preventative measure to take
    Sep 2007
    CQ
    Civic
    wouldnt bother, had many cars of relatives back in the US get some high miles since new, driving in the snow under harsh conditions, changing oil to the conditions and never have they bothered for a engine flush
    just change the oil, your car is still like new, hell it's only on 110k, just buy the Honda oil and filter
    WTB: EK oem JDM Visors
    I love J-Cups
    Jan 2009
    VTi-R
    Thumbs up
    Thanks guys! Ill get some Honda FEO oil and oem filter and chage it this afternoon. Ill see how it goes without flushing it with that Nulon oil flush.
    TRIPLE OG Array
    Aug 2004
    MEL/JPN
    b18c crx/that's
    regular oil changes is the best thing you can do
    but yeh if the engine is old or hasnt had the best service history it'd be a good idea
    i've seen k24's and k20's sludged so bad at 40-50k their vtc actuators and timing chains were fudged (due to lack of servicing/oil changes)
    Sep 2007
    CQ
    Civic
    Quote Originally Posted by panda[cRx] View Post
    lol, dayummm
    any pics?
    I can't get over some ppl who dont get it done at least at bare minium of 10,oooks
    myself personally I change the oil every 5,oooks as I can see this engine making 300,000+ based on what I saw when it was opened the other day, go oem Honda oil
    I love J-Cups
    Jan 2009
    VTi-R
    I also have an accord where i used a Nulon oil flush. But this was before i knew that there could be some build up and if this flush gets rid of them at once it could ultimately stuff the engine up.
    Has anyone heard of a Flush additive stuffin up the engine?
