Aim: carbon fiber look EK gauge/instrumentation bezel
Required:
(1) Self adhesive carbon fiber look vinyl
(2) Scissors
(3) Sharp cutter
(4) Hair blower (not shown on photo)
(5) MF towel
(6) Tweezers
(7) Ruler & pen
(8) Lots of patience
CF-look vinyl:
Steps:
This DIY started when I was cleaning my gauge as the instrument lights are already dim. After cleaning everything and I was about to put everything back together, I thought of giving it a new look.
(1) First step up removing the instrument cluster and taking out the bezel.
(2) Next is prepping the bezel. I washed it with dishwashing detergent and thoroughly rinsed it. Wiped dry with MF towel and air-dried.
(3) Trace the bezel on the backing of the CF-look vinyl. Trace line should be around half an inch from the edge of the actual outline of the bezel. Then cut along the trace line.
(4) Remove the vinyl backing of the CF-look vinyl then stick onto the bezel. Try to get rid of air bubbles. Then wrap the excess half-inch around the edges of the bezel. Use the hair blower to heat up the edge of the vinyl so that it will be more flexible. This will make it easier to pull the vinyl around the bezel edges. Fix the sticker onto the back of the bezel. Next would be cuting the 3 big holes (speedo, fuel/temp & tach). Remember to leave around half an inch so that you can wrap it arond the edge of the bezel. More important that you do this on these holes. I cut the 'excess' radially then wrapped the smaller flaps around the edges of the gauge holes. Heat up the vinyl flaps before pulling then and fixing on to the back.
(5) Next would be the small oval holes for the instrument/indicator lights. I did this by slitting a "*" on each hole using the cutter blade. Then repeat the heat-up-by-hair-blower and wrap-around-the-flaps process. Note that the flaps would be really small. You will need the tweezers here to pull the flap, wrap around the edge and fix onto the back of the bezel. Using the tweezers will also prevent dirt from sticking onto the adhesive part if you use your fingers.
(6) Reinforce the flaps at the back of the bezel (around the 3 big gauge holes and small oval holes). This will minimize the likelihood of the flaps from debonding and pulling back out to the face of the bezel. I used bits of vinyl stickers to do this. Cloth tape will also do. Looks ugly! Ghetto patchwwork.
(7) The finished bezel! Can’t wait to install it!
(8) Assemble the instrumentation cluster. Photo of the bezel installed on the gauge:
(9) Fit the instrumentation cluster back into the car. Photo:
(10) Lights on!
Enjoy!
Share the love and give a PQ point please...
