Hey all,
I finally have the ASR kit with all the endlink, bushings, D brackets etc and 22mm EK9 CTR Rear Sway Bar.
I just had some questions I needed to clarify before installing this on my 96' EK4.
According to the Instructions on the ASR website
eksubframe.pdf
Says i need the following...
Basic Tools
- Metric Socket Set
- Metric Combination Wrench set
- Metric Allen-head set
- Rag or shop towel
Safety Tools
- Safety Goggles
That i'll need to get from supercheap auto cause i have limited tools. Any other tools needed?
1. Do I need Grease too?
if so, what kind? and what/where do I grease up at?
2. It says "Install the backing plate and use the 45mm center flange bolt. Do not tighten until both sides are installed. Tighten to 20ft/lbs
What does 20ft/lbs mean?
3. Any clearance issues installing with a X-Force Twinloop muffler?
4. How long this take to install for you?
5. Any other tips or anything I should be aware of during installation?
Any help/tips/comments appreciated.
Thanks,
kriZy. (abit of a n00b)
