theres a bolt in the door handle, one in the bit where you pull the door shut, and one where the door meets the dash.
remove them
and pull it out from the bottom and take it off
some kids garage
A true car enthusiast appreciates the time, effort and money put into ANY sort of car, modified in ANY sort of style, whether they may like it or not.
Make sure your window is completely down as it makes it easier.
There will be a screw where the door handle is (sort of the arm rest area on door trim), remove that.
Where the door lock/lever is the is a small tab you pry it open and remove screw which allows you to remove the surrounding from door lock/lever.
Towards the inside on the door trim, towards the dash (pretty much directly right above the speaker cover) there is a plastic screw/wedge to remove
Once the three screws are removed you then pry the trim from the bottom corner (not the speaker end) with your fingers, and slowly pry along the bottom of the trim til the 5 (i think) clips detached themselves from the door itself.
Then remove the wiring from the windows switches on the inside of the door trim.
