Page 10 of 13 FirstFirst ... 78910111213 LastLast
Results 109 to 120 of 145
  1. #109
    Jan 2009
    Accord Euro Lux 04
    how bout 20x8.5?
    what tyres would you need to maintain comfort?
  2. #110
    Aug 2004
    Sydney Harbour Bridge
    03 CL9 Euro
    Quote Originally Posted by mattchuej8 View Post
    oh mad, massive help daz. +1 thanks.
    nO WORRIEs!!!
    I have 2 sets of wheels
    Both same size 18x7.5 but 2 diff offset +43 (gramlights 57 max TA wrapped in dunlop sp sport maxxx 225/40/18) and +50 (CE28N wrapped in Toyo T1R 225/40/18).
    Without changing damper setting on my coilovers by driving the car and swapping tyres with same tyre pressure they both ride differently, the toyo more uncomfortable than the T1R but also could be due to the fact that CE28N are lighter.
    Quote Originally Posted by mofolo View Post
    how bout 20x8.5?
    20 i think to be safe you'd need to run 30 or 35profile but might be a close to whether you need to roll your guards or not.
    Those sizes you'll need to ask the baller euro owners.
    vTeK 4-Life!
    FOR SALE: CL9
  3. #111
    Jan 2009
    Accord Euro Lux 04
    Quote Originally Posted by Crapdaz View Post
    lol.
    The only reason I ask is because the Evulve's E15 come in 18's and 20's.
    I wanted 19's damnit!
  4. #112
    Nov 2007
    Blacktown
    04 CL9 Lux
    possible to run 19" on 40-45 profile tyres?
    8===D
  5. #113
    Aug 2004
    03 CL9 Euro
    40 possible but alot of negative camber + rolling of both front and rear guards.
    vTeK 4-Life!
    FOR SALE: CL9
  6. #114
    Jun 2006
    Melb - Northern Subz
    Accord Euro CL9
    and also your speedo will be out of whack coz the rolling diameter is larger than stock. So prob have to get it re-calibrated or something. 35 profile on 19s isnt to bad....consider it a massage
  7. #115
    Aug 2004
    03 CL9 Euro
    Quote Originally Posted by TRaNz View Post
    It's not worth getting it calibrated.
    vTeK 4-Life!
    FOR SALE: CL9
  8. #116
    Jun 2006
    Accord Euro CL9
    Has anyone done it before? i havent heard of anyone gettin their speedo re-calibrated. They just go with bigger tyre and wheels and guess match their speed with other cars around them....LOL
  9. #117
    Nov 2007
    Blacktown
    04 CL9 Lux
    Oh thats right lol. totally forgot about the speedo issue. i was thinking comfort and looks. gah --"
    lol.
    what profile would u run on 20"?
    30?
    8===D
  10. #118
    with the correct profile tyre, theres no need to recalibrate the speedo,
    ie if you run a 225 30 20, its only about 11mm bigger. RTA gives you 15mm so thats fine and perfectly LEGAL in that area...But its the load rating you gotta watch out for, thats the other part of the problem(not to mention rim width as well)...
    For better comfort and looks, a 225 35 20 would be better, but this will throw the speedo out, and may also cause rubbing, however you could opt for a 235 30 20, this is wider and also higher so it will give a better ride. From memory it borders on the 15mm( i think its 16.? to be exact), but depends on your calculator so it should be fine. It is usually more expensive(from other places) though as its not as common as a 225 30 20.
    Taleb Tyres
    www.talebtyres.com.au
    42 Princes Hwy Arncliffe NSW 2205
    Need cheap tyres? cant find an odd size tyre? PM now
    Specialising in High performance Japanese Tyres
    (02) 9567 2888
  11. #119
    Mar 2005
    honda vfr800 98
    On a side note....has anyone who has replaced their standard 17 inch tire size with say like a 225 35? This size is more common then what honda fitted out the lux with and is 20 bucks cheaper or more in some cases.
    Any adverse effects on steering, handling etc etc?
  12. #120
    Aug 2006
    06 Euro luxury manual
    Quote Originally Posted by 10KRPM View Post
    Do you mean 235/45/17?That's the size that Commodores and Falcons use.This size is more commonly used and therefore cheaper.Not sure how you'd go with this size on the Euro as far as rolling diameter goes.PM Taleb above,he'd know.
