Originally Posted by ej20i
wad head unit have u got??if pioneer...its a common problem...so ground the rca
what do you mean by grounding the rca?
im wondering what that means too..
with pioneers they have a fuse for the RCAs. if you let the RCAs touch metal while the stereo is on then it can blow this fuse, it will make a buzzing noise.
grounding the RCAs is just that. get yourself a bit of wire, and bare both ends. tape one end to the outer part of the RCA plug and the other end to bare metal. play musaic,. if the sound goes, thats your prob
goodle grounding RCAs pioneer headunit
to see all of my build, checkout
Originally Posted by trism
omfg
very very rarely will running RCAs and power wire down same side cause buzzing, and if it doesit will be constant, NOT change with revs
the problem you are having is called a ground loop issue. it can be caused by a few things
your amp ground is not sufficient. make sure its secure, and on bare metal, strip all paint away.
This man knows. It is nothing to do with cables being run down the same sides.
It's because of a poor ground connection from amplifier to chassis.
Do as everyone has said, ensure the cable is screwed/bolted onto the chassis itself, not wrapped around a bolt on the parcel shelf for eg.
i have allso had this problem on my old car , and it can be lots of things ,did this start happen strait after the install or did it start ramdonly ?(as the way the cables are run can prevent or encourage noise), ill start with the easy things first , check all earthing points ,even the head unit i allways run 2 from it i.e the black wire and a wire from the case of the unit ,are they lose or rust is under them ? still no joy look at the way that the cables are run down your floor ,they should be as follows ,i start with main power cable i run it down the same side as the battery allthe way down the sill (between the seat and door ),then rca/remote down the middle (under console etc), then all specker wire down the other side from the power cable (allso between the seat and door), if you cables have to touch e.g front door specker wire over main power cable then make a cross , dont have them running parrallel (not even for a short distance), check that rca plug are a good firm fit ,try moving the plugs with your hand with the stereo on , if you still have the noise then its time to look at the bigger things , if you are useing an older amp (few years old or more) then try and borrow a mates one that you know is good wire it into your car and see if that works , next after that is looking at your alternater , get it checked out by a auto sparky they can drop diodes and still recharge your battery fine , but make heaps of noise , some of these thing may sound silly ,but all of them i have had happen too me and they can be very hard to find , or maybe a mix of different causes , hope this helps
alot of people forget to look at the ground that is attached off the battery..
most stock cars will be fine.. sometimes it helps to check the factory ground point at the battery..
for performance sound setups generally multipul grounds from the battery can help with engine performance and sound quality..
probally not the answer that you require but definatly worth a look.
failing all this you may need to earth loop the rca's as it quite offen causes alot of trouble have had to fix many a car with this fault but your 2 easiest solutions are as stated above thank you trism
lol i had this problem too was so annoying, you could hear it when i had a tape in and there was no music playing, like a blank spot on the tape. turns out it was a loose wire causing the problem, wasn't earthed properly.
Originally Posted by Bludger
I reckon there should be a right lane, a middle lane, a left lane and a Nikki lane.....
look at its headlights.
if its pupils have gone massive, you know its pinging
>_<"
Originally Posted by Riviera
lol its the RCA's and speaker wires running down the same side as the battery wire
plain and simple not earthing issues... earthing issues can cause
an amp to turn off/go into protect mode... not affect sound....
idiot
Originally Posted by tiksie
Got nothing to do with the headunit man, it will happen with every headunit depending on your wiring lol.
idiot
Who runs their ground to the battery from the boot ? :/ That's dumb.
Your remote + speaker wires should be on one side, and power/constant on the other side, it's causing static which excels when there is more stress on the alternator!
Easy fix, and damn annoying at first!!
roflmao at excelling static...
just listen to trism, i gave up posting advice in here ages ago due to examples like the above, does provide good lulz though
it could also be your RCAs... inferior quality RCA cables can induce noise... I had the problem... replaced my RCAs and now everything is going perfect...
But yes I run my power cable same side as the battery down the side... and the speaker and RCA cables down the other side... never had a problem in the 20+ systems I've installed... oh and make sure as said that you have sufficient ground... if you're using say a 2awg power cable then grab a small 2awg power cable from your negative battery terminal to the chassis for added measure... make sure you have sufficient ground in your whole system
