Results 1 to 2 of 2
    Apr 2004
    MELB
    04 S2k + track spec EG
    Question B16A ITB sizing questions
    Hey guys,
    I've been offered a set of 40mm throttle bodies etc, without a manifold, to go onto my B16A. One thing i just can't find is the port sizes for a std intake manifold. The reason I wanted that info is the more commercially available kits seem to have either 45,48 or 50mm throttle bores. So I wonder if I take this kit will I be reducing airflow? Because what I planned was to get another manifold and cut it up then tig the new tb's to that. The company that made the tb's has a manifold adaptor plate for $650 I think, seems a bit steep to me. Anyone got any technical input on CFM calculations?
    Thanks in advance boys,
    George.
    Jun 2005
    Melbourne, Australia
    Not a Honda anymore.
    It's a bit small for a B16. This would limit outright power to about 200HP. 45mm should let up to 260 which is plenty.
    You'll get some good mid range with the small TB's though.
    Competition Systems
    Motorsport Electronics
    Magneti Marelli, Jenvey and Digitek Corse
    www.compsystems.com.au
