update
im losing my mind , just plugged up each pipe , with some "bolts" from local car store only thing i could find
car is currently leaking coolant , went for a 1hour drive parked , found a big puddle
i then parked it on clean surface and bent over , and its pissing out , but thing is , its cold coolant , maybe its all coolant from the heater core coming out , i duno plz hep
D16Y4 powered rice rocket - stock as rock
Try taking it to a mechanic.
LOL geeang , bangbus as car , thats what we call mine
come on man , its not that hard to block of a hose , ozhonda thought me to change a clutch in a D16, im sure we could do this , i can feel it
update , just tightened the hose clamp due to was only hand tight with extension bar now its a few turns , lets prey
sorry to bitch , it just hurts this van is falling to pieces the O rings have now gone as well , its only got 140K km , and my mums only driven it A-B no flogging , same here
What O-rings?
If the coolant was cold and the car had been running at operating temp, it prob was just the heater core emptying out as there would be quiet a bit of coolant in there after pulling off the hoses.
The bolt + hose clamp trick will work aslong as you use an adequate bolt.
if you just block it wont it cause a huge pressure buildup causing small leeks to appear at any minor fault in the cooling system?
bennjamin says:
bennys penis shrunk abt when i started taking the 250 to 17000 llover the place
Fixed
next up is piston rings or whatever, or head work , due to blows smoke loads its oil for sure
cheers for help all good now
Just remember:
Black smoke = burning fuel.
White smoke = burning coolant.
Blue smoke = burning oil (which is BAD).
The cooling system is already under pressure. The heater core isnt a pressure relief. Your overflow tank is in system for the excess coolant to flow to.
ya its blue smoke , bad i know , me n mate will get engine crane n "strip" it, shouldn't be to hard
cheers for the help about the heater core
What are you getting an engine crane and stipping it for?
Are you now scrapping the thing, i thought you wanted it running.
Changing a set of piston rings definately isnt a job for a beginner. You will end up spending a fortune on tools aswell to get the thing done.
maybe , im selling it , if thicker oil dont work , il take it to a mates and ya
but i reckon some 20/50 should stop it , due to only 10/30 is in there atm
the thicker oil is worth a try i guess.
I dont understand what you need an engine crane for.
