Results 1 to 12 of 16
    Jun 2005
    Perth, WA
    EG5 B18c
    Running B18c with out a thermostat
    Is there any issues with doing this???
    Apart from taking ages to warm up???
    Any one actualy done it??
    Running honda Type 2 coolant, 1 year old alloy radiator, dayco thermostat(new)
    reason i ask is that i just replaced coolant and thermostat, and now my temps are sitting in high to mid 90s.
    my old thermostat is still like new but i replaced it anyways cause the temps were going to mid 90s, but now with new coolant and term its worse...
    fan is coming on at 96 97c now, before at 92c does the thermostat have anything to do with this its wierd...
    Nissan S15: 12.6@113mph
    Integra GSi: 15.1@91mph
    Civic B18c N/A : 14.1@98mph
    CRX B18c N/A : 13.9@101mph
    Jun 2005
    syd
    560hp
    bleed the system?
    if not, do so.
    you could also have a faulty fan switch.
    also you will get shit mileage.
    Jun 2005
    Perth, WA
    EG5 B18c
    bled it yes...
    till it was just a stream of coolant coming out..
    I didnt turn the heater on but would that be an issue??
    Jun 2005
    Perth, WA
    EG5 B18c
    its a 82c thermostat but lower hose stays cool till 100c
    could this part bit faulty
    Jun 2005
    Perth, WA
    EG5 B18c
    fan was working fine until i changed the thermostat
    Array
    Aug 2003
    Unit 5/15 Sefton Rd, Thor
    08 Red CU2 Euro
    Use OEM Honda thermostat.
    Dayco is rubbish.
    If that doesn't fix it, check the thrmostat bypass hose isn't blocked.
    You need this working to keep it open.
    Jun 2005
    Perth, WA
    EG5 B18c
    i took out an oem one
    its only 2 yrs old will it still be good
    i think the reason it was getting to mid 90s before was the coolant was crappy
    Jun 2005
    Perth, WA
    EG5 B18c
    were is the bypass hose
    Jun 2005
    Perth, WA
    EG5 B18c
    so running with out a thermostat is not a good idea???
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    without a thermostat, the coolant does not absorb the heat to transfer it, thus your cooling system doesn't work properly
    I tried this on my old car, in cold weather the car got too cold and in hot weather it overheated. Turned out to be a dud mod, which i did on the advice of a friend.
    Evo IX - THE FINAL EVOLUTION
    Hurstville
    jazz
    is there a bleed valve on B-series? where?
    Aug 2003
    EK
    Quote Originally Posted by gambate View Post
    There is a bleed nipple/bolt on the p72 head, not on a pr3 though.
    Abit of driving with the heater on and cap off/top a few times should more then take care of trapped air in the system.
