Page 1 of 3 123 LastLast
Results 1 to 12 of 32
    Sep 2007
    CQ
    Civic
    Noob Guide to monthly checks for EK Civic's and the D16Y4/7/8 engine
    The monthly check for EK Civics – a list for noobs
    My monthly check consists having a look in certain areas to ensure trouble free motoring.
    Checklist:
    Coolant level
    Clutch fluid level
    Brake master cylinder level
    Oil level
    PS level
    Washer fluid level
    And other misc inspections
    All that is needed for these checks is:
    1. A hydraulic jack, these can be bought from $50 and up, the one I am using was bought for around the $200mark
    2. Anti-seize packet, super cheap sells them for $1 a pack, bargain
    3. Metric socket set, you need one socket to remove your wheels, may as well buy the set as it will save you money in the future and at $13 for a new set at Super Cheap, why not, lol
    4. Torque wrench, a must have, $40 for a new one at yet again super cheap get one today
    5. Jack stands, you only need 2 but four is better, $20 and up per pair
    6. Paper towel, for checking oil dipstick
    7. Cloth, for wiping your hands during the job, gloves are optional at this point
    8. Level even ground to work on
    9. Solvol soap bar
    Ok, time to get started; it all starts in the cabin. Now open the bonnet via the bonnet latch under the dash.
    Once the bonnet is open you can see the bay, start by checking the level of the brake and clutch reservoirs, all fluids should be up to the proper marking and if any are at the low or below the low point, there may be a problem and you should seek mechanical advice very soon. But if you are low, wipe off the cap(s) on the reservoir and top up ethier with Honda brake fluid to the correct level as a temp fix til you get to the workshop.
    Now check the power steering, it’s located near the windshield reservoir, dust off the red cap and pull the cap off, you will see the level on the indicator in the cap, if it is low, top up and find the cause of this problem.
    The windshield reservoir is easy to assess by removing the blue cap, the level should be up to the mark and if it’s low top up with dematerialized water that can be found at any grocery, hardware, or automotive store. If you want to refill the reserve use some Honda washer additive, costs around $3 for a small bottle that can treat a few litres of distilled water, will rejuvenate your wiper blades and clear your screen of bugs with ease
    Also I might add to check and replace wiper blades, at the very most they will cost $9 from Honda (reuse the old metal inserts for your new blades)
    Apply RainX and/or FogX for the windows (especially good coming into Winter) - this stuff is pure gold!
    Now to check the oil level in the sump, by pulling up the orange dip stick pictured you can view the oil level, the first pull should be wiped off with a napkin, rag or cloth, and then put back into its holder, wait a second, then pull it up to view the level. The level should be up to the second mark, my pic has it below that mark as it was on the stands at the time and not level, it is important to do all of the checking on level ground.
    Then check the battery, if it’s an oem item like the ones I buy, it will have an indicator located on the top, a good battery will glow a bright green as indicated in the pic, if it changes color, get a new battery, also make sure your terminals are clean and free of build up.
    If you have an older style battery that requires routine maintenance - top up the water level in each of the filler holes with demineralised water.
    Now check the coolant reservoir, it is located next to the radiator and should be to the max line, if it is low top it up with Honda coolant or if its below the low line, seek further mechanical advice as there could be a leak in the system.
    Now you can close the bonnet, now get out the torque wrench and required socket piece to loosen to finger tight level your wheel nuts, you may have (should have) wheel security locks, that will require a special socket, loosen that one first then the rest in cross fashion.
    Once you loosen both of the front wheels nuts, you can now jack up the front end, make sure the rear wheels are secure using wheel blocks, engaging gear, and the handbrake on. Locate the factory jacking point in the front and jack it up enough to put the locked jack stands into place.
    Factory jacking point
    Factory jack stand points for the front
    Now remove the wheels from the hubs and inspect for wear and foreign objects, noting anything you may find. I use a Bob Jane tyre indicator card to indicate wear levels; it’s a good guide as to when to seek a tyre expert.
    Note the foreign object, remove stones from all gaps in the tyre
    Just a side note, with the drivers front wheel removed, you can see the transmission fill and drain locations, fill on the left, drain on the lower right. To check the transmission level, remove the fill bolt and stick your finger in the hole, feeling below the inside thread as the fluid should be up to the thread, if its below it, top up with Honda MT fluid until it pours out a lil is the best way.
    When you put the wheels back onto the car, use some of this anti-seize on the studs, this will ensure long life to the studs as many workshops who will touch your car are overly rough and have no care in the world towards it (nor use anti-seize in the bizarre belief that It’s unsafe… ok it stops seizing and cross threading, its win to me when you properly torque wheels, been doing it for yrs, so has my Dad, and his Dad and not one of us has lost a wheel or had to replace a wheel stud…)
    $1 a pack at super cheap, you’ll only need one for all the studs with heaps spare
    Wipe your hands off after you put some on the studs
    Now have a look at the cv boots for wear, as you can see this boot is in top shape still
    WTB: EK oem JDM Visors
    I love J-Cups
    Sep 2007
    CQ
    Civic
    Now put the wheel back onto the car only hand tightening the nuts, remove the jack and lower the car. Now set your torque wrench to 80 Foot Pounds, then tighten all the front wheel nuts in cross fashion til it clicks.
    Now time to do the rear of the vehicle, in the pic is where the rear coupe point is, roughly the same for the hatchback and sedan models. Do the same as the front wheels then jack it up and put the jack stands on the rear factory points.
    Once you’re done doing the same check as the front wheels, lower the car and check the torque of all wheels is the same.
    I would also check the next time you fill up fuel (or if you have an air compressor) the tyre pressure
    Tire pressure should depend on size and intended purpose.
    As a rule of thumb for street use, lower profile tires should have higher pressure. 36 - 40 PSI .
    OEM size 30 - 35 PSI
    I check the tyres, coolant and oil levels every time I fill up for fuel
    Now you can check the operation of the lights to check for blown bulbs, may need a friend to help with the break lights, this is the only way I knew I had a blown license plate bulb in the rear.
    When I’m done if I have time I usually wash the wheels and car and use some kitten tyre shine to clean up the tyres I’ve been touching earlier. I do this check once a month with good results as its easy to find problems doing it this way than to wait til the normal service intervals Hope this has helped a few noobs out there, please feel free to comment, cheers.
    also a beer would be nice afterwards
    I love J-Cups
    Newcomer Array
    Dec 2008
    Western Sydney
    Great guide,
    EK's monthly bible !
    Nov 2007
    In the pit
    A black one
    Yeah wd ryan.
    Can you use the anti-seize to bat off with?
    Anyone selling a black ek1 facelift Hood (OEM)?? PM ME
    Sep 2007
    CQ
    Civic
    Quote Originally Posted by Gio View Post
    Yeah wd ryan.
    it stains skin to a point where Sovol has to be used, isnt waterbased, I can see you having difficulties... lol
    I love J-Cups
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Great work mate!
    Sep 2007
    CQ
    Civic
    Cheers Brett
    may come back to update it a bit with more common Civic info on the D16 models
    I love J-Cups
  8. #8
    Jul 2007
    JDMD15B
    14EGs/8EDs/3EKs
    Where did you jack the car from ? Your bumper ? lol
    JDM D15B - you wouldn't understand
    No K-SWAP ? No worries - Unfriend
  9. #9
    Mar 2008
    treasury casino
    150 bus
    Quote Originally Posted by tiksie View Post
    read it~ it says factory jacking point ~
    nice write up ryanator
  10. #10
    demineralised water is a bit overkill for the windshield imo.
  11. #11
    Dec 2004
    Melbourne
    RD7
    u use your torque wrench to undo lug nuts ?
    Quote Originally Posted by ChargeR
    Ozhonda mods don't sleep, they wait.
  12. #12
    Sep 2007
    CQ
    Civic
    has two way locking point (tightening and untightening), plus theyre only at 80 FT Lb. wont damage the equipment one bit
    anything with leverage will do as some tyre shops (the ones neara me) will do them way too tight unless I tell them it do 80, lol
    I love J-Cups
